Internet Radio dropouts, possible solution
Posted by: tigersclaw on 14 May 2015
Hi,
As a Uniti2 owner, I have been troubled by internet radio dropouts for several years. I have tried almost everything I found in this forum including switch ethernet to wifi, using upnp based radio instead of iradio itself, and using a better router/switch. All these measures have worked somehow, yet generally speaking I am still not satisfied with my internet radio perfomance. 320k stations have so many dropouts that I can only give them up. 256k and 128k stations usually have little dropouts in the morning, yet in the afternoon whether they are listenalbe depends on luck. BTW, I live in Shanghai, China, and my ISP is China Telecomm.
A few months ago, a local buddy told me that a small router including VPN function sold online would significantly improve iradio performance. I tried and then the 320k stations became listenable in the morning and sometimes in the afternoon.
Last week I noticed an add-on service by China Telecomm named Internet Elite. The web page said that this service will use a new internet connection which will increase my international band width. My internet connection is 100mbps, yet this band width is just applicable domesticly. I have been guessing that the poor iradio perfomance was due to my poor international link speed. And now I have a chance to give it a test.
The result is positive. With this Internet Elite and also with the vpn router, I now can listen to any iradio station any time in a day without a single dropout. The only problem is that Internet Elite almost doubles my internet cost, which is now about $600 per year.
So, buddies of the forum, perhaps you can consider your international band width while trying to improve your iradio performance. The data your ISP provides you may only be domestic. Try to ping vtuner.com and see the delay. For me it was 4xx ms before and 1xx ms now.
Also, I will try to find if the vpn router is necessary for the new performance. If not, I will stop using it and restore my previous one. Will keep you updated in this topic.
