At last! A quality friction gear lever set for flat and comfort bars ...
Posted by: George Johnson on 17 May 2015
If you have a great road frame with down tube friction gear shifting levers, then till recently you had a problem moving the gears to to handle-bar.
Finally IRD have come up with a less than cheap, though nicely made , solution:
http://store.interlocracing.co...umb-shifter-set.html
You will need a pair of these:
http://www.totalcycling.com/en...--Alloy/m-18936.aspx
and some skill or a friendly Local Bike Shop to fit, but for us older people it solves a problem of trying to keep riding our favourite bikes of thirty odd years ...
ATB from George
