N-serve App v2.1 crashes
Posted by: David Hendon on 23 May 2015
Several of us still have problems with the n-serve App crashing when the iDevice is woken up. Since the last update, I still have the problem, but it has changed somewhat in two ways. Firstly I now get crashes when moving from the Rip screen to the Albums screen. Not always, but often. This never happened to me prior to v 2.1, not even once.
Secondly I have discovered that although the App appears to close, if you double-click the home button, the App is still showing as running and if you select it by touching the small App screen, it comes back to where it was when it appeared to crash.
it also seems to me that the App is less prompt about synchronising when you have just ripped a CD to the US. Has anyone else seen this?
i hope this helps someone.
