Dawes New Album WARNING
Posted by: lutyens on 02 June 2015
This is a warning. I have just received my vinyl copy of the new Dawes album. I therefore went to download the digital version using the code card and have been infected with MacVx.
Be very very careful. To remove it on a mac go to safari preferences, extensions and uninstall. It will take you a while to get there if you have got it but you will get there.
Posted on: 02 June 2015 by King Size
Thanks for the heads up, this is on my shopping list and I would have used the voucher on a Mac.
Posted on: 03 June 2015 by King Size
Thanks Wat, Have just checked and my Mac is clear.
KS
