Angle the mu-so upwards
Posted by: dave-mac on 10 June 2015
Has anyone tried placing something under the front of the mu-so to angle us upwards?
I have mine placed at standard tv-stand / coffee table height, which is about 1ft less than ideal. I thought a couple of rubber wedges to angle the mu-so upwards at the front might help direct the tweeters to ear height. So, has anyone done anything similar?
Posted on: 11 June 2015 by Eloise
I've not tried this ... but how about a couple of desktop speaker stands you can get for small desktop monitors.
The one's I have seen are called "ISO Acoustics L8R130 Speaker Isolation Stands", though I suspect their may be others available, and they tend to be from pro-audio stores.
Posted on: 16 June 2015 by myNaimisMark
Hi dave-mac
I have done just that, placed two small rubber feet under the front of the mu-so.
I used a lazer level to get the height correct in relation to my listening position. Made a big difference to the sound.
Cheers...
