Transcoding to WAV on the Fly from Synology
Posted by: Mr THX on 16 June 2015
Hi
Which Server software do you guys use which transcodes FLAC to WAV?
Problem being if I use the propriety Synology 'Media Server' it transcodes fine to WAV but when I play any concerts (Springsteen 24/192) it fails to play gapless...
If I use MinimServer it does play a concert gapless.... but I can't get it to transcode to WAV ?
Any ideas?.....
Err no? Is this the bit I'm missing..... sorry for the stupid question but does this sit on the Synology OR the control source? (iPhone/Pad)
If you Google minimstreamer transcoding you'll find a link to the instructions page, including the specific transcoding part.
For some reason the latest Java update seems to have made my computer and minimwatch fall out with one another, so I can't paste the little bit of code I entered to make it work here, but all I did was follow those same instructions and it wasn't too tricky.
Cheers both, found all the pieces and I'm in business ![]()
Just checked and its transcoding, both to 16bit and 24bit and the Springsteen concerts are playing gapless..... excellent.
Also like that you can add a bit of album art which shows up in the folder view on MinimServer on the Naim App
Chris
Is it difficult to install Minimserver and maintain updates later on. What it will give me more that standard Synology mediaserver? I did not realized so far any problems with streaming 24/192
I can't comment on 'updates' as I've only just started using it... it is easy to get up and running though. For me it gives me Gapless playback when listening to live concert downloads..
I have a few of the Bruce Springsteen 24/192 back catalog concerts and enjoy the smooth transition of the songs without the breaks....
But installing, I'd say it's intermediate level stuff. You do need to install another programme (minimwatch) on a computer to manage it, and getting the codes to get it to function how you want right can involve a bit of trial and error. So it's not quite at the 'click here and everything magically sorts itself out' level of ease of use, but neither is it a half finished coding nightmare.
But I prefer the way it organises & displays my collection to the way the Synology software does it. Since the browsing experience/finding what you want, how you want is such a big part of using this kind of equipment, it's certainly worth the small amount of effort required IMO.
I had never heard of Minimstreamer before! I'll have to see if I can get it installed on my Synology and QNAP nas's.
One nice thing to play with is the HLS high quality (~1500kbps) BBC radio streams, if that sort of things floats your boat (as it does mine). Googling should yield appropriate instructions.
Not available to us in the States unfortunately!
Are you sure? As it streams direct rather than via iplayer or similar, I'm wondering if it bypasses regional issues.
I've had no issues downloading podcasts, for example, from numerous other countries, the States included. Maybe it works like that?
I even cannot download Java :-( I am using MacOs and I get this message:
| Your browser has "cookies" and JavaScript enabled. | |
But I did all, enable JavaScript and cookies are enabled :-( so I am lost
strange that other Java version I can download but not the version I need (for Synology 212j - ARM5 )
Hi, now it is working. Just I installed v7 .
Minimserver is running now and I enjoy folder view
Now I am trying to install Minimstreamer but I cannot find where are the properties for package instalation :-( it is so difficult to install all of these features.. pls help
IIRC it's via minimwatch that you check minimstreamer has installed correctly too.
Hi, thanks. I still wanted to find and install on NAS. Now it works
