Paused streaming from NAS, after a while, do not work; is it normal?
Posted by: bicela on 17 June 2015
Dear All,
if I pause a song streamed by NAS (Synology and native media server) and I come back after one hour or so (maybe even less) the music is not restart from the paused time.
It is happening to you as well?
Posted on: 17 June 2015 by Mike-B
Hi Maurizio,  yes same for me.
I rarely do it but assume its because either the iPad goes to sleep or the Synology hibernates.
Posted on: 17 June 2015 by ChrisSU
I've never had this issue when an iOS device goes to sleep, even after long periods, so my guess is that's not the problem. (I don't use a Synology NAS for music, but as the Naim app only talks to the streamer, I imagine the same would apply.)
There are plenty of ways to stop a Synology NAS from hibernating, so that theory should be easy to test:
https://www.synology.com/en-uk/knowledgebase/faq/568
Or maybe it could be caused if a network connection is temporarily lost. I have occasionally lost a play queue in that scenario before.
Posted on: 17 June 2015 by bicela
Dears, thank you for yours answers.
I use not hibernation for my NAS, but the same hardware of Mike, maybe it is a 'limit' of Synology media server.
What do you use Chris?
Unitiserve. Yes, I'm lazy
Thanks!
Posted on: 27 June 2015 by bicela
Dear, just for confirming that is a Synology issue, I now use MinimServer and it works fine.
