Time
Posted by: lobo14 on 29 June 2015
As far as I can see Naim have not yet managed to sort out the time zone problem.
If this is the case something should be done ASAP to fix it.
Makes me wonder what other times they have messed up.
Can someone from Naim clarify?
Posted on: 29 June 2015 by ChrisSU
I presume you mean after installing the firmware update released today? I did my streamer today, and it shows the correct time.
Posted on: 29 June 2015 by lobo14
I do mean after installing the update out today.
Mine does not show the correct time.
When adjusting the time zone to +2 it just jumps back to +1.
Thus showing the wrong time here in Norway
Posted on: 29 June 2015 by pgmvveld
It works fine for me now in the Netherlands after re-synchronising the internet time once the update had finished.
