NDX
Posted by: Pepiva on 29 June 2015
Hello.
I have received my NDX last week.
Check my system.
I will keep you posted.
Best
Giuseppe
Hello.
Check my system.
Best
Giuseppe
Nice system.
Hello.
Check my system.
Best
Giuseppe
Checked - no NDX - what happening to CD5 ??
What NAS are you using, how is system setup - wired or wireless.
Nice piece of kit ! plug it wired to your network and use a good server (Assetnas or Minimserver) and you will really enjoy your music.
have fun
Hello.
Check my system.
Best
Giuseppe
OK but why keep CD5 ??
What about the NDX set-up, is it wired or wireless & what/how stores the music
I get this feeling that it might be useful. I have about 5,000 cd's. Should I sell it? I never sell anything (I have a spare NAC72, a NAP140, and a NAIT02).
Music will be stored on a QNAP TS 231+ NAS. The NDX is wired to a switch, no wireless connection, which also ports the NAS and is connected to a Netgear DSL modem - router. My iMac is directly connected to the modem router. Do you have any comments or suggestions? Thanks.
Excellent, nice network setup, the switch is a positive "must have" IMO to get the best out of a network, irrespective of how good the DSL router is.
5000 CD's will take some time to rip & will need a lot of TB, but I bet once they are all ripped you will not play the CD5. Then think about CD storage - how big is that in your house for 5000 CD's ?? compared to that little QNAP box !!!! It will free up a lot of house room once they are in storage boxes.
Ive kept my CD5XS, and it hasn't been powered on in over a year! It's just taking up a shelf on the Fraim.
I have mine in plastic general storage boxes, In UK they are found in all home product stores such as Ikea, sorry but don't know Italian store names.
I selected my box dimensions deliberately to store each CD case on end with the end title strip showing, this means the box internal must be at least 15cm for normal case size/shapes, some odd shapes mean a bit more. My storage boxes are 17.5cm deep & 40cm x 60cm max on the top (lid) .That size is about as heavy as enough to carry around when full of CD's.
The box top is profiled to enable the base to fit & boxes to be stored securely on top of each other. The only other advise is don't store them in an attic, a friend did that & the heat of summer melted & distorted them all.
5,000 CDs while be quite a chore to rip - you only want to do it once, so make sure you do it right.
Don't use any lossy compression (MP3, AAC, etc.). On your iMac I would preferably use a program called XLD or the Mac version of dBPoweramp. Don't use iTunes, as there is no way to check if a rip is bit-perfect during ripping. Be sure to use a "secure ripper" and query the "Accurate Rip Database" (these are XLD settings, but dBPa should use something similar). Output to FLAC at a minimum (if drive storage is an issue), but again preferably AIFF (in a Mac environment). Embed the highest resolution artwork you can find (at least 600x600, but bigger is better to future proof).
I'm not sure if you can get these in Italy, but I've just found some boxes that work well for me....
have fun
I assume you are doing this with an iPad or Anroid pad & not the naim remote.
What UPnP media server are you using with the QNAP ??? what UPnP package does it come with ??
whatever it is, thats all you need; so if you do not have a QUAP package supplied media server, you need to follow QNAP instructions & install one. Asset is probably the best, but Minimserver is also good.
Clear the cache
Clear the cache
Clear the cache
Re-scan or re-index the server on your NAS; MinimServer doesn't update automaticall when you add files.
Regards, alan
Clear the cache
Regards, alan
Sorry, I have no idea how that emoticon got involved...
if if you go to the MinimServer status under your Synology "installed" applications page, it will hop you to the web interface for free (port 9170, I think it was...but you don't need that). On the status page, you can hit a re-index button to update your library with the new uploads and any other changes. Best wishes.
Regards, alan
Regards, alan
Hi Pepiva,
In MinimWatch, "rescan" tells MinimServer, running on your NAS to look through your music library and update its database with all the songs, metadata and so on. "Refresh" tell MinimWatch to query MinimServer for current status information. as an example, if MinimServer is not running on your NAS, say because you just updated the DSM software and have not yet gone into the Package Center and chosen "Run" after the update / reboot, then MinimWatch, running on your Mac, shows a bunch of greyed out menu items. After enabling MinimServer to "run", when you hit "Refresh", those menu items are no longer greyed out, and the Properties, say, reflect the current live settings being used by MinimServer. The top MinimWatch menu items are "pass through" commands for MinimServer; the bottom group (of three: Options; Refresh; Exit) are "local" commands for MinimWatch itself (ie: "stop" stops MinimServer, but "exit" exits MinimWatch). I hope that makes sense.
My feeling on your "obsolete" question is that you have nice equipment and need to learn how to keep it up to date. For my part, Naim have been very busy updating firmware and App software to add new features and improve stability and performance. I have a SuperUniti and a (first generation) UnitiQute, and am well pleased with the ongoing support. I think NDX owners have enjoyed the same level of support. Much of the discussion on the forum from people who are not feeling "safe" about their forward-looking experience seems to be with the hard disk player / ripper / server products (HDX and UnitiServe, if I have it right), since these products serve local content (eg from their own local store or a NAS) but will not be upgraded to serve online content (eg from Spotify or Qobuz). I don't know the details, but Naim have stated that this would not be an appropriate addition for these products, while users point to, say, the two different "categories" of applications that can be run on a NAS (ie both a UPNP server for local content, and an Internet streaming "relay" client that listens to, say, Spotify, and sends it out over UPNP to any and all listening clients). Clearly a difference of opinion on what "music serving" means, just as there is a divide over the design decision to implement only "connect" style Internet streaming services (ie Spotify connect but not Qobuz or Tidal, which use a different interface and are readily added to Sonos-type devices just as new internet radio stations are added elsewhere).
TL;DR : you are in the group of Naim owners with the most aggressive level of support via new firmware. Relax and enjoy your gear for years to come! That is certainly my plan...
Regards, alan
