Internet radio lost - help please
Posted by: JSH on 15 July 2015
With the help of many here, I've just moved from wireless to wired connection via a bridge.  My UpnP server (Minim) is working beautifully (thereby suggesting the connection to the router is fine) but I cannot get Internet radio to connect at all either via the handset or the Naim app ( android).  The front of the Qute2 just shows BBCR3HD as "connecting" but it does not connect.  The same with Audiophile Classical
When I first went to wired a day or so the radio worked well, so something has happened.  If I go to iRadio on Naim app I do not get the menu for Podcats, Stations etc, jut a blank screen
I have reset the router, turned off the bridge and the Naim and unplugged them for a half hour but nothing still (Thankfully, the Minim is still OK)
Can anyone help please?  Many thanks
Posted on: 15 July 2015 by robgr
Check your DNS settings, could be that it stopped working due to lease expiry and now something is amiss at the renewal
Posted on: 15 July 2015 by Phil Harris
Hi,
If UPnP is working correctly but Internet Radio isn't then it sounds like a gateway / DNS issue.
If you plug your Mu-so directly into your router via a wired connection (without going through your wireless bridge) then does your Mu-so connect to internet radio?
Phil
