Neat's fall short after upgrade from XS to XS2 and from Dynaudio X12 to Neat Motive SX2
Posted by: Bjornvs on 22 July 2015
Wanted to share this experience and hoping for some good advice
So I upgraded from XS to XS2 and from Dynaudio X12 to Neat Motive SX2 and expected more from the neat's
My current/previous setup.
MacMini / Audirvana / Vertere Pulse D-Fi / Arcam irDac / 222connect-litz / Naim Nait XS / Atlas Equator 2.0 OFC / Dynaudio X12
This week I had a very good second hand deal for a Naim XS2(2014) and a set of Neat Motive SX2
I couldn't check them out before buying due to distance, but the price was good so probably can sell for at least the same.
Both seemed like a good upgrade and expected the biggest difference from the Neat's
Yesterday evening I checked the new setup. Both connected the new speakers and the new amp, I was too curious about the total upgrade.
Right away I was very happy with the result. The new Neat's seemed way more balanced with my setup. My previous setup could be too forward and fatiguing. With the neat's I wanted to go loud and still enjoyed without getting too forward.
But soon I was missing something in certain songs and changed back to the Dynaudio's X12 with the new XS2. The sound stage was bigger and more lively compared with the neat's where the sound is more glued to the speakers, warmer, more body.
One big thing is that my X12's are placed perfectly for my room. I don't even dare to move them because a slight change can make a big difference(maybe I'm going crazy). The neat's were next to the x12's but because they are so low they get boundaries of my sofa and stereo furniture. I did place them more forward too remove most  boundaries, but still. Left neat speaker though is almost clear of any boundaries and still sound is more attached to the speaker then with the x12.
I didn't expect the XS2 to make a big difference compared to the XS, but maybe it did and improved my X12 experience more than I expected.
But really expected the neat's to be a big upgrade to the X12's.
Or is it that the character of floorstanders is a bit unexpected.
Another thing is maybe my speakers cables don't work well with the Neat's
I used to have naim nac A5, but in my previous setup preferred the Atlas and the NAC's are impossible to work with.
I'm also looking for tellurium q black's which seems highly regarded
So did I misjudged about the Neat's and is it more a side step instead of forward. Should be quite a bit better looking at the price
Posted on: 22 July 2015 by SmauG
Positioning of your Dyn's is optimal and positioning of the Neats is not, this is hardly a fair comparison becouse of:
1) Interferance of the sound by the other speakers resonance, and
2) Position of the speaker influences bass response
The step up from the dyns to the neats is marginal when considering price (stands included) so it's a matter of taste and room compatibility here.
You are in a very luxurious position with both speakers in house, so defore you decide to drop the Neats try this:
Mask the floor exactly where your dynaudio speakers sit with some tape and place the Neats in this exact position. Move the Dyns away from the listening zone.
From this point, make small adjustments, this might be needed due to the slope of the neats, to get the bassdriver on the same distance from back and side walls.
The hight of the Neats has its influence but this is only little.
Take some time to figure out what position/toe in works best and what speaker suits your listening habits best. Then make your descision, Sell the obsolete pair and enjoy your music
Posted on: 22 July 2015 by Bjornvs
Thanks for your reply.
I've kept them side by side so I can switch easily, because else I can find it difficult to compare when there is too much time between the switch.
I'll put your tips to practice tonight.
Specially the taping of the magic spots
Posted on: 22 July 2015 by Bart
I really do think that the drivers of the speakers that are not connected can "suck up" some of the sound.
I like my Dynaudio X12's too  I have them on a Qute2/NAP100 little system.  Very musical and enjoyable.
Posted on: 22 July 2015 by Huge
With speakers, in some rooms, like with houses, there are three important things: Location, location and location!  The presence of the other pair of speakers can also affect the sound.
I suggest making some templates (paper, wood or card) to retain the position of the stands for your Dynaudios (I prefer templates to using tape on the floor).  If you decide not to keep the Neats, you can then know you've put the Dynaudios back in exactly the same location.
Then remove the Dynaudios (and stands) from the room and experiment with the position of the Neats.  You may be surprised (or you may not!).
Whilst there are guidelines for positioning speakers in regular cuboidal rooms, they are no more than guidelines as other things like furniture affect the result.  As speakers vary in bass extension and off-axis response, the perfect place for one type of speaker isn't necessarily best place for another type.
Yes great little speakers, but do neat a lot of care with positioning. Still in my room I can have bass problems even with more than 50cm distance from the rear wall. Also the soundstage and imaging is off with a slight position change. At leat in my room, all will be different somewhere else.
Thanks for the tips and so true about the possitioning! I've experienced that with the x12's, Though in reviews and certain forums read that the SX2's would be easier with positioning, but maybe not in my room.
I do notice that at very low volume the XS2 has a balans problem
First stereo image shifts to the left and when even lower only the left channel works.
At this forum read about someone else having the same issue. Asked the seller if this was the case with this amp and he said no. Salesmen, you can never trust them
Posted on: 22 July 2015 by Christopher_M
Although you have already found the ideal position for the Dyns, I'd try the Neats back towards the wall a bit for the sound to be less glued to them. Even if that puts them into a bit of conflict with sofas, other furniture, line of sight etc.
Chris
Most Naim preamps and integrateds use ALPS 'Blue' potentiometers for their volume controls.  For various manufacturing and mathematical reasons, despite them being a very high quality component, there's always a certain degree of variability between the channels and this is most obvious at the low volume end of the tracks.
It's a matter of chance whether or not any specific box has the problem to an audible degree, and if so  to what degree it's there (I'm very lucky - my XS-2 doesn't have the problem at any detectable level).  I was however aware of the problem when I used the same component in my own amplifier designs, but then I could make adjustments by hand to 'trim out' the effect to some degree.
Posted on: 23 July 2015 by Bjornvs
hmm, ok so it isn't by default a defect if it occurs.
I'm waiting for a response from the shop, let's see wait they say
Chris
Thanks will try this tonight though afraid the bass will get too overwhelming.
Can a tile(marble?) underneath the speaker(bottom ported) have a positive effect on possible booming bass?
Posted on: 23 July 2015 by hungryhalibut
Buying speakers without hearing them in your room is always something of a lottery, but as you said, you bought them for a good price so can sell without loss.
There can sometimes be a feeling that if lots of others like a speaker it must be you that is somehow at fault if you don't like them. I tried some Neats once (the Motive 1, which I bought without hearing because they were cheap) and they were absolutely awful in my room. There was so much bass it was just unbearable.
So if you don't like the Neats, get shot of them. Ported speakers are the work of the devil.
Posted on: 23 July 2015 by Christopher_M
Chris
Definitely worth a try. The Motive SX2s sound glorious at my dealer's driven by any Naim, with which they have a great reputation. I notice his are pulled out further than I could give them here. I'm trying to suggest that you will have to experiment with positioning, but I think you are saying that you have already pulled them out a bit further than the Dyns and that the sound is still glued to the boxes. Could be worth moving the Neats a bit closer together as well as further out.
It may just be that you prefer a rear ported standmounter to a floorstander with down firing port in your room. In which case sell the Neats and valuable insights into your room and audio preferences gained.
Chris
Posted on: 23 July 2015 by Huge
Hi,
Also look at this thread.
https://forums.naimaudio.com/to...26#37468652721354826
One person was complaining of low volume balance mis-tracking on a NAC 552, so it even affects Naim's high end products.
Chris
Try blocking the ports (e.g, shove a towel under each speaker, touching the bottom on the cabinet and the floor).
A ported box is acting as a Helmhotz resonator.  If the tuned frequency of the resonator is close to one or more of the main resonance frequencies of the room, the the bass will sound 'boomy' and have a 'one note' character.  Blocking the port can sometimes be enough to tame the bass in this situation.
How big is your listening room?
   Ha! Caught between the devil and the deep blue sea!
See above and just run them as sealed boxes!
Thanks for all the information and tips. Helps a lot!
Yes i've been moving a lot with the neat's and the x12's out of the way. Still not sure what's best.
My experience in my room with a ported is a painful one, previous year purchased 4 gik 244 panels, did improve, but would need bigger bass traps and don't wan't to go further that road, don't want my room to look like a studio.
My living room is mostly concrete and is a L-shap. the listening position is in the foot of the L with the speakers at the long wall. Long wall is 8 meters, on the right side 5 meters conservatory(mostly glass) and behind me also 5 meters. Woden floor with a carpet between speakers and listening position. The concrete is probably the biggest reason for the bass problems. Mids and Highs improved a lot with the gik panels
I think best for my room would be front ported, no port at all or maybe the system pmc uses. So much want to try a pmc twenty 23, but too expensive at the moment.
About a towel in the bass port. The x12 I use without the plugs because it also destroys the mids. I've used these plugs now with the neat's and expected the same, but not really. Boomy bass almost gone and the rest still seems there, so that gives me more options with placement. Though would not be that happy if I need to use the plugs, because like to able to use a speaker with it's full potential. But with plugs far better at the moment.
Using the plugs in the ports doesn't remove the speaker's 'full potential', it's a way of tuning the bass response to particular rooms.
The reflex ports increase the bass output across one small range of frequencies.  If these frequencies are already being accentuated by the room acoustics, having them increased by two separate mechanisms isn't what you want, as the bass can then become overpowering in that narrow range.
If you can't tailor the room acoustic with bass traps, then putting the bungs into the speakers is the next best option (and the speakers will actually produce bass transients a bit faster).  If the room already increases the bass at these frequencies you aren't losing potential from the speakers, you're just loosing an overemphasis.  The bass extension remains the much same, the only thing that changes is how that's achieved (i.e. using the reflex port or using the room resonance).
Incidentally, my room is even worse, I have to use both bass traps and bungs in the reflex ports to control the bass!
I use PMC 23s and they are excellent. The transmission line exits at the front and there are no bass issues at all, it's just deep, agile and tight. Unless you are totally convinced that the Neats are overwhelmingly better, I'd take them back if possible, and save up for something that will really work. It sounds like you've got the Dyns working very well. You certainly don't want to be fannying around with towels.
HH, transmission lines aren't a silver bullet.  If the tuning of the transmission line and its port matches a room resonance, then you'll have exactly the same problem that occurs if a speaker's Helmholtz resonator matches the room resonances (and the answer to the problem is the same: block the port or the exit of the transmission line!).
However I believe that the transmission line of the PMS 32s is tuned to a lower frequency than the reflex enclosure of the Neat SX2s , so they may work better in his room.
P.S. The towels was just a simple way to conduct an experiment to see if it was worth moving the speakers to properly install bungs into the reflex ports.
Posted on: 23 July 2015 by gary yeowell
PMC23 bass was about a second behind the beat of the music in my room.
Posted on: 23 July 2015 by GraemeH
That's one hell of a transmission line .
Posted on: 23 July 2015 by dayjay
Where the 23s in the same room?
 My room has not been kind to speakers with any kind of hole in them.
Thanks for this clarification! And yes seems to work very well with the Neats. Not with the X12's but that's probably due to the small stand mount body and maybe gets almost all is lower tones from the bass port.
I'm not that technical with audio, just want to enjoy music, that's why I can get nervous with new stuff. Simply just want it to work so I can go through all my tracks again and relax, but often not that simple
Now with the bungs I can even put them closer to the wall. Measured from the speakers first rear  corner to the wall 25cm. Not sure what's the right method to measure this, rear, middle or front speaker? There's 2.5meters between them
Maybe I've reached to point where I might decide to keep the Neats.
Yes I had this thought a lot about selling them and waiting for a good PMC offer, but that changed after using the bungs. Still though would love to try the PMC's if I ever get the chance.
