Naim NDS not working after power cut
Posted by: Dungassin on 23 July 2015
Well, we had one of hour (all too frequent IMO) short lived power cuts this morning. Following this, as sometimes happens, I had to reboot the routed (Netgear N600) and reconnect the wifi extender (also Netgear) using the router setup software. This time the power cut also managed to switch off my QNAP NAS (where I keep the music files and nothing else). I have Asset installed on that device as my server.
Got my iPad back up and reconnected, but NDS just says 'No Device. Connect USB/iPod'. Switched the 555PS off/on ... same message.
The NDS is connected via a Netgear switch, so I tried running a separate ethernet cable to the NDS. Still no joy. Tried switch with other devices. The switch is working OK. Added a few music files to my WD My Cloud device and made sure it's DLNA server was switched on. Still got same message from NDS.
The only thing I haven't tried is to go into the QNAP setup and make sure that Asset or Twonky are still there and working.
So it looks like the NDS may be winging its way back to Naim for some TLC.
