Personal Observations on Resolution, Sample Rate and Data Compression
Posted by: Huge on 28 July 2015
I've just been making some tests using a set of files of a clarinet concerto, using different data encodings, converted using dBPoweramp.
1 24/192 (the source file)
2 24/48
3 16/44.1
4 16/48
5 MP3 variable rate
6 MP3 320kbps
All files are played from a USB memory stick.
Files 1 - 4 are WAVE format.
Files 5 & 6 are MP3
Characteristics observed to change
A There is a sudden orchestral FF tutti a few seconds into the piece, in good conditions this is sudden enough to make me 'jump' a little.
B The solo clarinet is distinctly separate from the orchestra in timbre, it being closer to the microphone.
C There is a difference in the perceived location of the orchestra and the soloist including general information from the 'sound environment'.
D There is a subtle difference in the reverberation of the orchestra and the soloist due to their different location in the hall.
Results in comparison to file 1
2 24/48
A The sudden jump at A is very slightly softened, but I still 'jump'.
B,C,D Changes are below the threshold of certainty.
3 16/44.1
A The sudden jump at A is considerably softened, to the point where I no longer 'jump'.
B,C Changes are below the threshold of certainty.
D The difference in the reverberation is no longer detectable
4 16/48
A The sudden jump at A is somewhat softened (closer to 24/48 than to 16/44.1), I still 'jump' slightly.
D The difference in the reverberation is no longer detectable.
5 Variable Rate MP3
6 320kbps MP3
B The individual timbre of the clarinet is less distinct from the body of the orchestra
C The presentation is considerably 'flatter'.
These are just my observations based on one movement of a concerto; but, it was chosen to show up potential issues, and I believe the original 24/192 to be a good recording:
Weber Wind Concertos, SCO, Janiczek. Linn CDK 409
