Reset Mu-So Network Settings
Posted by: Taylormade on 03 August 2015
For something so easy to use, I cannot find any way to reset the network settings. I have tried the factory reset but it still somehow connects to my wifi.
When I set up the Mu-So last week, I didn't have an extra ethernet cable to use at the time so I set it up with wifi. I now have connected an ethernet cable and cannot figure out how to get the Mu-So to switch to using the ethernet.
I know it keeps connecting to the network via wifi because I'm looking at the attached devices to my router and it is listed under the 2.4 wifi and not wired ethernet.
Posted on: 03 August 2015 by J Saville
Hold the reset button in for more than 4 seconds, this will factory reset the mu-so. All of the lights should go out and then it'll flash for about 2 minutes.
Posted on: 03 August 2015 by Taylormade
Thanks J. Already did that several times and it appeared that the Mu-So was connecting still via Wifi to my router.
Finally I decided to reset the router and now it's showing the Mu-So is connected via ethernet. You would think the refresh button on the router page would have shown the update but it didn't.
