and yet another PC problem.
Posted by: Mr Mole on 10 August 2015
Couple of weeks ago, I rebuilt my PC: Gigabyte mobo, 16 GB RAM, i7-4GHz proc, etc etc
Started the interminable process of re-installing the software, starting with Win 7 Pro 64-bit. Loaded the basic OS and chipset drivers, and then let Win Update do its thing for the next couple of days. So I got SP1 & a humungus number of KB patches & .NET frameworks until the only thing remaining was Internet Explorer. I don't normally use IE, preferring Chrome, but before the rebuild, IE 11 had been installed and had got me registered for the freebie upgrade to Win 10 via the icon in the task bar. Would I install Win10? Who knows, but if MS wish to give me a free copy then it would be churlish to turn it down
The problem is that IE11 resolutely refuses to install! I know it'll run under Win 7; it was fine before the rebuild! I have crawled all over the MS site, run the "troubleshooter", checked that all the IE11 Pre-requisites were in place, tried "running up the scale" from IE8 (from the installation disk) to IE9 then IE10, and then retried IE11.
Nowt, nada, zip. The install routine gets about 40% along the progress bar, then bombs out with the useful "IE failed to install. please use the troubleshooter icon handily located on your desktop".
Needless to say, I have tried the troubleshooter......several times!
The rest of my apps are fine, even Photoshop 2015....now that they've released a patch - and daughter 2 has been playing something called Dragon Age: Inquision, which, she tells me, needs a "hot" machine to run.
But this IE11 issue has been bugging me.
Anyone got any ideas as to what to try next.....other than a complete reinstall, or parting with money for a retail copy of Win 10, which (a) rankles and (b) diverts money out of the "Second Olive NAP250 Fund"!
Posted on: 10 August 2015 by sjbabbey
Haven't installed Windows 10 yet (still on Windows 7 64bit Pro) and don't use Internet Explorer. However, if I go into Control Panel > Programs in W7 on the LHS there is a link to "Turn Windows Features on or off" which if I click it opens a dialog box with the various Windows components including (in my case) Internet Explorer 10 with a checkbox you can tick to activate. Is there something similar in W10 and have you tried this ?
Posted on: 10 August 2015 by Mike-B
Yes the same prog "Turn Windows Features on or off" is in Win-10
However its turn on/off Explorer 11 on my Win-10 which is a bit strange as Explorer has been zapped in 10 & its now called "Edge"
You need to upgrade to 10 or you will be left in the Desert of the Lost Soul's (no support)  It really is OK & its marketing hype is only surpassed by its failure to live up to the "you will be amazed" hype, its all rather logical & easy to use.  That said while the style has to be gotten used to & it may not suit those that don't like change,  it does work & it does everything well & it is really getting closer to PC for Dummies (if that's what you want)  but it does retain the flexible tailoring abilities of previous OS to satisfy the IT nerdish.
Posted on: 10 August 2015 by Peter Dinh
That's odd, IE 11 has always been there for me since day 1, but it does not show up by default. I am using IE 11 every day to remote log in my work computer via Citrix.
You need to search for it by clicking on the Start Menu, type IE.
Posted on: 10 August 2015 by TomK
You may want to uninstall IE 10 first.
Posted on: 10 August 2015 by Mr Mole
My Win7 installation disk is pre-Circkus.... err, sorry wrong forum. I'll start again
My Win7 Installation disk is pre-SP1, so it comes with IE8, which it happily installed during the initial phase of the rebuild. it was when Windows Update was attempting to install IE11 that thr problems started.
And @Tom, yes I tried that trick of installing IE9, then IE10, then deinstalling IE10 and installing IE11 (all from kosher MS download packages) but still the same outcome.
 @Peter & Mike, before the software rebuild, I also had IE11 which had auto-installed on the five-year old (or thereabouts) Win7 system via Windows Update. It is curious that it now refuses to install on my "new clean & shiny" Win7 Pro-64 system.
I'd forgotton about the  "Turn Windows Features on or off" buttons. I'll play around with that this evening.
Posted on: 11 August 2015 by robgr
Firstly, do consider going to Win10. It's more like Win7 than Win8 so will be familiar to you 'straight out of the box'. There's lot's to admire with Win10 as others have stated and it's very configurable too if you're not happy.
Also IE11 will co-exist with Edge if you prefer IE11, not yet used Edge myself as I use Firefox but looking forward to having a play as it's getting a lot of attention for all the right reasons, e.g. HTML support and Cortana integration.
Regarding the IE11 installation issue, try disabling any A/V (turn on Win Firewall first). Ensure that any previously installed IE versions are completely uninstalled.
Check that there is no system restart pending or any windows update in progress. Finally review the IE prerequisites, see https://support.microsoft.com/en-us/kb/2847882
Posted on: 11 August 2015 by Mike-B
I've just unchecked IE-11 & it does not apear to have changed anything - Edge apears to work the same  .....   will keep trying  .....   MicroSoft say in their help pages "  .....    there is minimal impact on third-party programs (and other parts of Windows itself) that call upon Internet Explorer application services, because the Internet Explorer files that provide functionality to third parties and other parts of Windows are left intact."
Posted on: 11 August 2015 by Bananahead
Be a bit careful with being enthusiastic about Edge. It is very new and feature incomplete. Some sites don't render properly - Flickr for example. Extensions are not available yet. Having said that, I am now using nothing else.
Posted on: 11 August 2015 by Peter Dinh
For some reason, I was under the impression that you already installed Windows 10
Since you are already on Win7 Pro-64, I would recommend that you upgrade to Windows 10 for free, I did and I am not going back to Windows 7.
But having said that, you need to do some backup before the upgrade just in case you do not like Windows 10, or you come across some issues unexpectedly.
Posted on: 11 August 2015 by Mr Mole
No, I reinstalled Win 7 so that I could get the free update via the icon in the task bar. The icon will only run under IE 11.
I hear you about backups , but I'm "safe" in that all documents, photos, music, etc are either on the D:\ and E:\ hard drives (obviously the OS is on C:\)* or the NAS.
*and these are physical drives not partitions.
Well, Mr. Mole - You do not need to wait for MS to do the upgrade, you can go to the URL (https://www.microsoft.com/en-u...e-download/windows10) and upgrade it yourself, and that was what I did.
If  the link (http://www.microsoft.com/en-us...e-download/windows10) does not work for you, you could google, and you will get there eventually.
I'm giving up trying to get IE11 installed (I don't use it anyway) and have downloaded Win10 from the link on this and t'other thread.
So I think we can close this thread.
