TIDAL streaming with Oppo Blu-ray players
Posted by: Silence Kills on 11 August 2015
I just got an update for the Oppo iOS app which requires a new firmware for my beloved Oppo player.
The new firmware is available here and includes TIDAL support:
https://www.oppodigital.com
Release notes:
"This release is for the OPPO BDP-103, BDP-103D, BDP-105 and BDP-105D Blu-ray Disc players.
Special Notice:
  1. Once this Public Beta firmware is installed on the player, you can revert back to the previous Official release via a USB thumb drive. There will be no issues upgrading to any future official or beta firmware release.
  2. This Public Beta firmware is designed to work with new versions of Apple iOS and Android MediaControl applications, which added support for TIDAL Music Streaming. The Media Control V4.0 will be available in the App Store and the Google Play Store shortly.
Comparing to the current Official release version BDP10X-77-0827, the major changes included in this version are:
  1. Added support for TIDAL Music Streaming. Requires use of OPPO MediaControl App v4.0 on your smartphone or tablet.
  2. Improved subtitle support for user-created media.
  3. Improved support for user-created WAV files with non-standard metadata tags.
  4. Improved gapless playback for 176 / 88.2 kHz WAV files.
  5. Resolved an issue with smearing or ghosting effects in Netflix.
  6. Resolved an issue where AIFF file playback would result in white noise when headphones were connected to the BDP-105(D).
  7. Resolved a bass management issue where the subwoofer would clip when 0 dB signals were sent to all channels when one speaker was set to small.
  8. Resolved an issue with smearing or ghosting effects in Netflix.
  9. Resolved a frame rate conversion issue where 25 Hz and 50 Hz user-created media was converted to 60 Hz when TV System was set to Multi.
  10. Added support for ARIB STD-B25 and ISDB fonts.
  11. General disc compatibility improvements based on recent and upcoming Blu-ray releases as well as user-submitted disc samples.
All features and improvements of the previous firmware are also included in this version."
Posted on: 11 August 2015 by marcusman
Oh and why can't Naim do the same?
FWIW
It works!  The sound isn't too bad for a Public Beta.  I'm sure it'll improve over time.  Ease of use is very well done.
Nice workaround until Naim integrates Tidal.
Posted on: 12 August 2015 by Felty99
Good to see Oppo continuing to improve its players with streaming functionality.
It also appears that they have ironed out the bass management/Sub clipping issue for those of us using the analogue outputs.
Posted on: 12 August 2015 by marcusman
+1 I know its still in Public Beta but I hope they continue to improve their SQ as well.
