Error Message in dB Poweramp
Posted by: Greensleeves on 03 September 2015
I should be grateful for some understanding and advice in respect of a problem I have just encountered in attempting to rip a CD in dB Poweramp.
For the first time in almost 600 CDs the rip simply refused to work, and the message under the heading 'Core Converter' was, 'Error reading dB Command File'.  I have subsequently ripped another CD and that was fine, so I am at a loss.  Could anybody explain, please?
Posted on: 03 September 2015 by Guy007
Did you close the app, re open the app and try ripping the cd again ? Same error ?
Other processes going on while the PC was ripping ?  Your PC might have had a 'moment' for whatever reason... happens to the best of us, especially when multi tasking.
Posted on: 03 September 2015 by Tony2011
I had to close and open app a couple  of times  while(still) ripping my load. Could be defective CD. Also worth checking disk space.
Posted on: 03 September 2015 by Mike-B
Send an support note to dBpoweramp
Mr Spoon is the font of all dBpoweramp knowledge,  he posts in here somethings as well
I believe it might be a problem reading a file in the dBpoweramp software,  I would reboot & try to rip it again - then post to Mr Spoon
Also 15.3 is the latest dbpoweramp version, with v2 of Perfect Tunes...  so make sure you have the latest
