Minimserver Issue
Posted by: IanG on 03 September 2015
I've recently switched to Minimserver on my QNAP Nas so that I can transcode from FLAC to WAV. All has been good apart from one strange problem I get intermittently.
Occasionally when playing HiRes material it will insert a short pause every 20 seconds or so. The time interval is constant.
It is fine streaming standard CD rips. If I switch back to Twonky (I have both installed) and stream the HiRes FLAC file all plays ok.
Has anyone else had this issue and do you know how to fix it ?
Posted on: 03 September 2015 by gert
You should better ask this in the minimserver forum. The minimserver developer, Simon, always tries to help.
