NDX broken?!
Posted by: MartinKocurek on 04 September 2015
Hi I have some problem with NDX , iRadio not working, NAS streaming not working. Music from USB is working. It looks that there is some problem with network card inside NDX. Other home devices working properly on my home network.
What do you think? Back to dealer or still some possibility to fix myself?
Posted on: 04 September 2015 by MartinKocurek
Factory reset did not help :-(
strange is that when I unplug LAN cable and plug in again it works appr. 30 sec and than it stops and I cannot connect again.. i have tried different LAN cables and it is the same.. After each reconnection of LAN cable it works only few seconds
Posted on: 04 September 2015 by hungryhalibut
Have you tried turning off your router, switch and the NDX itself, and then rebooting them all. It sounds like a connectivity issue rather than the NDX being faulty.
Hi HH, I have restarted everything what I could and seems working again. I will test few hours and hopefully it will be still OK.
Many thanks
That's the thing with computer audio: turning it off and turning it on again seems to cure many ills.
Posted on: 04 September 2015 by Bart
Swap cables to test the cable.  Swap ports on the router or switch to make sure it's not the router or switch port (or whatever the other end of the cable is plugged into!).
Do the little lights on the back of the NDX at the ethernet network input blink to show activity?
Posted on: 04 September 2015 by DaveBk
It's funny... I was halfway through replying to this earlier, but my iPad crashed... Now following a reboot all seems well. Computers certainly are a source of sress...
