Hmmm which cable to upgrade?
Posted by: feeling_zen on 04 September 2015
Already a similar post at the moment I know but different systems have different requirements. I have been pondering a change to the cabling for a while but not sure what will give me the best result. Should state upfront there is ZERO chance of an audition so taking a chance on a non Naim cable aint gonna happen.
Guess my options are:
Power cables
Interconnects
Speaker cables
Current cable to unit setup is
NDX/XPSDR > HiLine > 282 > SNAICx2 > SCDR > Naim  basic XLR > 250.2 > Atlas Hyper 2.0
Using the basic power cables supplied by Naim. But did have a dedicated mains spur installed for the system. A5 is out because I chose the Atlas over it on purpose because it was better to me.
Am feeling the XLR is the weakest link but have been told it is not as crappy as it looks. Lumina not impossible but full loom is out of the question. Kind of wish Naim did more options of HiLine level interconnect as that may make more sense but am led to beleive that is not possible. Wondering which Naim cable changes would give biggest impact.
No change is an option too. I love how the system sounds.
Suggestions? Experience?
Posted on: 04 September 2015 by JRHardee
I know it's not an answer to the question you asked, but if you have the price of a Lumina cable waiting to be spent, I'd seriously consider a box upgrade.
Posted on: 04 September 2015 by feeling_zen
Fair enough. There is no resale market for Naim in my country though and not sure which box would necessitate and upgrade. Seems like a well balanced combination of boxes to me. Be curios to know what you had in mind.
As I said, would prefer to go full loom at HiLine level but I don't think there are suitable HiLine equivalents of SNAIC (which has to carry power too) or the XLR.
Posted on: 04 September 2015 by hungryhalibut
I guess that the SL IC and din to XLR are the options really. But if you are willing to take a punt, Witch Hat do a din to XLR replacement; the wonderfully named Hatpin 4x. I've just got one for my 272/250DR but have not had a chance to try it yet. It's shielded, like the SL lead, but only costs £120.
Posted on: 04 September 2015 by Skip
Every time I have added a Powerline, I have heard it immediately and it is not a subtle change.     It gives a more focused, full,  and fleshed out sound vs a stock or other cable.  If I could, I would try it on my coffeepot.
I can't say the same thing for a HiLine, which is pretty darn subtle by comparison, and I have not heard the new SL cable.
Try it and see.  You might prefer a more airy sound.    You just have to try it at your house.
Since I live in the land where proper hi-fi went to die and there is no such thing as Naim here, trying something is not an option. I basically have to buy it and pray. Hence the rationale that I won't try a non Naim cable since at least I know with the Naim, the worst that can happen is I get poor VFM but am fairly sure it won't break the delicate balance of how the system sounds.
Am curious about the Power Line. Is this giving a significant benefit even where the hi-fi has a dedicated and isolated spur on the mains? Am convinced of the positive effects of decent terminations at each end that isolate the equipment from vibration and RFI carried over the cable, but not convinced why a new lead is required when the power tap and the cabling behind the wall and everything to the power substation is basic industrial standard. Would have thought a small decoupling adapter on the end of a normal lead would have been just as good.
I have a dedicated mains spur, made from 10mm cable and with its own consumer unit. Adding Powerlines makes a significant difference, so yes, they are definitely worthwhile in my opinion.
Posted on: 05 September 2015 by MDS
A Powerline is a low-risk buy since you have five boxes and can try it on each one to see which gives maximum benefit.  I started with one and put on the Naspc for the 282 and that's where I'd advise you to start.  I found it boosted the 282's performance to a significant and surprising degree.
Mike
Posted on: 05 September 2015 by Skip
I have dedicated circuits and earth-based ground grids for my system.    You can definitely hear the Powerlines.    No doubt your hypotheses about why it should not work are solid, and you may be right.   But you can readily hear the Powerlines in an all Naim system.   They make it sound even more Naim, so if you like the sound before Powerlines, you should like it better with Powerlines added.   I even have one on my turntable.
Posted on: 05 September 2015 by feeling_zen
Seems like some overwhelming votes for PowerLine as a cost effective upgrade over the other options. Might get my dealer in the UK to send me one. If I like it I can buy more.
Interesting that everyone (I checked some old threads) advocates the benefit of the PL on the NAPSC. I heard that this is the one place Naim said it makes no difference. But I don't think everyone can be wrong. Will give it a shot.
Posted on: 05 September 2015 by Manu
Powerlines is an option, but I would consider starting with a Lumina Din5-5, then the din-xlr. Source first is still the rule.
Posted on: 06 September 2015 by MDS
I don't think that's true. Indeed, I think the idea of trying a PL on the Napsc came from one of the good folk of Salisbury.
M
Posted on: 16 October 2015 by feeling_zen
So I took the plunge despite some skepticism and put my funds into 3x PowerLine for the 250.2, SCDR, and XPSDR. Everyone spoke so highly that I thought I'd give it a go.
Bit surprised and still disbelieving at the difference it made. I commented once that adding the SCDR to the 282 had an amazing impact on clarity to mid to low frequencies but not much at the top. Well the PL seems to have taken care of the other end of the spectrum. Ignoring the fact that these are power cables, it was a very cost effective upgrade.
Did try some combinations with the PL on the NAPSC instead. Can't say I heard a difference. I'll have to agree tlo disagree with people on that. But in general, thank you to everyone who helped talk me into the PL.
Posted on: 16 October 2015 by mikapoh
I also have a 282/250.2 based system using Hiline and Powerlines. After a chat with Doug Graham a few months ago he advised to try SL Din-XLR for a start before changing other cables. However, I can vouch Powerline is also a very good option for the price.
I asked my dealer about the SL DIN-XLR and his response was "if you have to choose between one or the other, put the money set aside for the SL and do the DR upgrade on the 250.2 instead".
So after the PL I am indeed doing the DR upgrade first.
Posted on: 17 October 2015 by Harty601
Zen, for what it's worth - the Hatpin is on a 30 day money back guarantee. Not sure where you are in the world, but all you've got to lose is the price of postage (included in price within UK).
I'm going to give one a go between my 272/250DR.
Posted on: 17 October 2015 by feeling_zen
The postage, duty, insurance from the UK to Japan would make the 30 day money back a bit useless. If I didn't like it, the round trip would be nearly as much as the cable.
Though for 130 squid (let's call it 180 by the time it gets here) it might, as HungryHalibut says, be worth a punt. I'm tempted for sure. On the other hand, I've heard many dealers who could have flogged me another cable tell me that the stock Naim DIN-XLR is not the piece of crap it looks like.
Decisions, decisions.
Posted on: 17 October 2015 by nigelb
The stock Naim Din/XLR isn't as crap as it looks but the Hatpin is simply better.
Posted on: 17 October 2015 by Chris Dolan
Powerline is a good option - I would put it on the NAP250.2 where I would expect it to be most cohesive, but it's worth experimenting
Yup Chris, that's what I've done. I stuck 3 PowerLines on the 250.2, SCdr, and XPSdr. The debate now is what to do with stock DIN-XLR between the SCdr and the 250.2. Leave as is or try out a Hatpin.
Posted on: 17 October 2015 by AussieSteve
Bruce Richardson, the owner of Voodoo Cable in the US told me the power is the foundation of the house, I'd suggest you start there. I did and it was worth it's weight in gold.
Forgot to mention, after that it should go sources - pre - power - speaker interconnects. Cheers.
Posted on: 18 October 2015 by Chris Dolan
I've not tried any Witch Hat cables - but I've heard good reports on the Hatpin.
I think I'd be inclined to let the system settle down for a while and contemplate a DR upgrade.
Posted on: 18 October 2015 by feeling_zen
Seeing as the PLs are now in place on the source, pre, and power amp since a couple days ago; a HiLine on the source and dual SNAICs on the 282 to SCDR have been in place for 18 months and the speaker cable was sorted from day one, I think I'll give the Hatpin a whirl. Compared to everything else, it is hardly a bank-breaking expense.
Should have one arriving in the next week or two. That should take the system in it's current incarnation to it's final resting place cable-wise - unless I think it sounds naff in which case I will remove it.
As for the SL discussion, It would make more sense in my mind to change the electronics. I'm on the list for a DR upgrade to the 250.2 next year and my dealer is starting to whisper sweet nothings about a 252 (which I have stated I have no intention of upgrading to but we'll see). Planning on building a second home in a few years and with that would come the opportunity to start again with a new system - maybe based around 500 series (or whatever the equivalent is at that time). SL could well come into that discussion.
Posted on: 18 October 2015 by hungryhalibut
Let us know how you get on with the Hatpin. I'm glad a got mine, and for £120 they are great value, and beautifully made as well.
Will do. It was mainly your recommendation that tempted me to give it a try.
