Minimising wireless dropouts on SuperUniti
Posted by: Tweed1234 on 10 September 2015
Hi there
After being suitably forewarned about the perils of wireless streaming on the SuperUniti, I was ready to think about living with running hideous lengths of Cat5/6 all over the house (my router and server is 2 rooms away from the living area where the SU lives).
I use JRiver as the media server on Windows10, and have a collection of hi-res 24/96-192 tracks from HDTracks, in addition to a large collection of WAVs and FLACs.
Straight out of the box, sound quality was exceptional when it was connected. I could detect no difference between wireless and hard-wired. That said, there were dropped connections every hour or two, with the SU taking anywhere from a few seconds to 30 seconds to reconnect. Occasionally I needed to switch it on and off again for it to reconnect.
Pretty disastrous, considering I'm using an ASUS RT-AC68U - fairly high spec dual band Gigabit router (handling a 1Gbs fiber).
The solution turned out fairly easy in my case. On advice from a friend, he suggested the problem being network overcrowding - I live in a fairly built up area where every home is basically running high bandwidth connections. I downloaded WifiInfoView, a freeware (and legal!) wifi scanner which looks at the network and sees which network channels every one is using.
There are 13 channels in total, however they all overlap with one another, there is some advice to stick to channels 1, 6, and 11 as they overlap least. That said, they also tend to be the most popular default channels that routers go to.
So based on what the app picked up, I changed to one that had the least usage (in my case 10), and there was an incredible change in reliability. I maybe get one dropped signal once every 3 days or so, but the system reconnects in a matter of seconds. And I never have to restart the SU.
I have been told that it is possible that routers may dynamically change channels, and I may have to change it every now and again, but it hasnt happened to me yet. To me, potentially having to log in to the router every few weeks to change a channel is a small price to pay for reducing wire clutter.
Wired clearly is most reliable, but just thought some of you might like to have an option to try out. It's worked very well for me so far.
