Naim NAP 100 and DragonFly DAC
Posted by: AJK on 13 September 2015
Hi,
Can anybody advise me when a DragonFly DAC will work effectively with the Naim NAP 100 Power Amp.
I am looking it as a temp measure until I can afford a V1
This should work. Not sure how good it will sound, but it should work.
From AQ webpage
- USB Stick-Size Digital-Audio Converter
- Plays All Music Files: MP3 to High-Res
- Drives Headphones Directly
- Variable Output Drives Powered Speakers or Power Amp
- Fixed Output Feeds Preamp or Receiver
Just use the variable output mode
This is what I also read on the Dragonfly manual.
Has anybody got any experience
No, but I do own both. You'll need a fairly unusual cable, but aside from that it should work. The sound quality will be rather limited because the Dragonfly costs just over a hundred quid and has a 3.5mm jack output, but it should be listenable. And the NAP100 is brilliant.
I certainly haven't regretted owning a Dragonfly for when I'm traveling. It's far better than my regular laptop's DAC, incredibly convenient to use and works well with mid-range headphones (and maybe better, haven't tried). So even if it's short term, or the SQ with the NAP100 isn't perfect, the Dragonfly is a useful thing to have.
Hi
AudioQuest do a cable. 3.5mm - 2 RCA (Evergreen) 0.6 m - £25.
Br,
Andrew
Hi
Br,
Andrew
As a suggestion, you might also consider the iFi nano iDSD dac. It costs a little bit more, but has RCA outputs and a proper analog volume control - so perhaps theoretically a better match for something like the 100. Its reviews are very strong indeed.....
