Qobuz vs Tidal
Posted by: Peter Fransen on 19 September 2015
I have a Qubuz subscription and a one month trial subscription to Tidal. I have an old iPhone5 connected to my WiFi. I have Tidal installed on it and stream the output to apple TV which is optically connected to my UQ2.
I do this exactly the same with Qobuz. Both using the same setup, the quality of Qobuz sounds better to me (should not be, but still). I compared each time the same tracks of the same albums. Qubuz comes close to my own ripped CD's.
Does anyone share the same experiance?
Posted on: 19 September 2015 by DHT
Tidal here, it is exactly the same as my ripped CDs why wouldn't it be?
H
Posted on: 19 September 2015 by Simon-in-Suffolk
DHT, what transport are you using for Tidal. I use a Sonos as well as others, and it can sound close to my locally streamed CDs, but ultimately not as good.. Perhaps it's down to the fact Tidal uses FLAC and I locally stream WAV.
Also Tidal seems to frequently use different masters to that used on my CD copies, where there is a difference occasionally I prefer the Tidal version, but more usually the other way around.
Posted on: 19 September 2015 by Tommy Torvald Sjøman Torvaldsson
I have a Mac mini with amarra and tidal into dac v1 and unitqute2 with Spotify using 24/96 bnc out to bnc in to dac v1. Mac is omptimized and is used only for music . The sound is okay with a big airy soundstage . But my oversampling Qute is way more fun and soundstaging is not far behind..
Posted on: 19 September 2015 by SongStream
To the OP, that is exactly my finding, and except where the masters are different, I maintain that Qobuz is as good as my rips, to the extent that I've only ripped at this stage the CDs that cannot currently be streamed.  I did try Tidal not long after launch, and didn't get on with it for a number of reasons, and did feel the sound quality was not as good as Qobuz for some reason.  I understand they have improved their PC apps to offer better sound quality, but being content with Qobuz, and Tidal costing the same per month, I'm not likely to re-evaluate it.
One thing I would say, you may find either perform better if the streaming source is more direct. Having a phone, WIFI, and an apple TV in the mix before it reaches the UQ2, may introduce issues not just with reliability, but with general SQ as well.
Posted on: 19 September 2015 by Goon525
At the risk of sounding like a broken record, Qobuz has two huge advantages for classical listeners - gapless playback, which means you don't get gaps of several seconds in the middle of continuous pieces of music where the track number changes; and access to CD booklets, and thus notes, libretto etc - in most but not all cases. Tidal are still promising jam tomorrow on both counts.
Posted on: 19 September 2015 by hungryhalibut
If you like jazz or classical, Tidal is utterly useless. Qobuz, on the other hand, is really superb. If Naim ever get around to integrating a streaming service, let's hope it's Qobuz. Or both, as I understand that Qobuz is not available in the U.S.
+1 One annoyance though is that the Scottish company's label doesn't feature on Qobuz at all, and there's some damn good stuff in there.  I know they've integrated with Tidal in their streaming products, and I guess that's why.  I wonder if they would have made the same decision with hindsight.
This is worth a read, though the author's failure to mention the importance of gapless for classical listening is a weakness:-
http://www.sinfinimusic.com/uk...ssical-music-in-2015
