Dry Edging vs Wet Mortar
Posted by: naim_nymph on 19 September 2015
Any builders, roofers, architects, surveyors like to lend me their advice, experiences, opinions please....?
Presently having roof repairs done;
the lads are doing a good job repairing a leaky roof, replacing guttering, repairing a chimney stack and fitting a new pot.
While up there with scaffolding all around, the opportunity of having a routine overhaul of the ridges, edges, valleys, is being undertaken.
I'm happy the way things are going but the only niggle on my mind is the application of a modern plastic dry edging system. The house is only parted fitted with the stuff so far, it looks neat from a distance but i think that's because it's new [and from a distance].
The fascia boards are wood with wood-stain, which go with the style of house, but the new dry edging is interfacing with the wood fascia and barge boards which makes me wonder if this will trap moisture and cause the wood to rot...?
The house and fascia boards are 26 years old and in fine condition except in need of a fresh coat or three of wood-stain. The south side wood has (over a 26 year period) warped in the sun and is being replaced with new wood freshly wood stained to match the rest of the house.
I have a horrible feeling the new plastic dry edging will also warp on the sunny side, and the black colour with fade or discolour...?
I can understand how a plastic system of edging may work well with a new build house that has upvc eaves too, but does it make sense on an existing house that is heavily styled in wood and mock tudor styling?
Dry Edging
Ease of fitting any time of year, quick to fit, good choice of colours, looks neat, don't need painting,
may assist roof ventilation.
May blow away in a gust of wind if not fitted securely,
or worse may remain and look like cheap plastic tack.
May discolour, warp, or look odd after a decade or less.
Wet Mortar
Traditional way of edging tiles, nice natural material look, can last a quarter of a century before needing attention.
Can crack, fall out, look a mess, especially if not applied correctly.
Please feel free to discuss and give advice, opinions etc : )
