62/140 vs Brio r
Posted by: CFMF on 27 September 2015
I have a chance to buy an unserviced 62/140 combo. I would use it in a LP12/es14 system. I am presently using a Brio r in said system. Would the 62/140 (once serviced) be an upgrade over the Brio r ?
Thanks in advance,
BBM
Posted on: 27 September 2015 by hungryhalibut
I'm sure it would. Maybe you should put the ES14s on your main system, they'd be better than those Spendors.
