Right angle hdmi keystone connector
Posted by: Willy on 21 April 2011
Anyone got any idea where I might find one of these in the UK, or even internationally from someone who is prepared to ship to UK?
Finally getting around to burying all the cables in the walls/ceiling and installing in-ceiling speakers. Have sourced all the bits I need except this item. The buried HDMI cable will come down the wall in a conduit. If I use a straight through connector then I need to go rather deep into the wall to allow for a smooth bend in the hdmi cable. So far I've been able to find straight through keystone connectors and right angle connectors but the keystone right angle connector is proving somewhat elusive:-(
Willy.
Posted on: 22 April 2011 by Mike-B
Does this one do it for you - prob is its USA
http://www.amazon.com/HDMI-Key...lation/dp/B002I6QIE6
Alternative is to forget Keystone & go for another wallplate
Lots of these around
http://www.nexxia.co.uk/products.asp?section=Audio%20Wall%20Plates&category=HDMI%20Wall%20Plates%20Angled&gclid=CMfpsonar6gCFYob4QodCXK5HQ
http://www.amazon.co.uk/Cables...-Right/dp/B002UOOUKU
Posted on: 22 April 2011 by Willy
Mike,
Had spotted that one but they only ship to US. Will probably get someone over here to purchase a couple and forward them on.
Leaning towards keystone as I can build up the config of sockets I need, basically Hdmi and 5 off 4mm socket pairs. May also sneak another ethernet in there as well. All the pre-configured wall plates seemed to use binding posts, which although they can take 4mm plugs are less neat.
Willy.
