Uploading information to Naim's music database
Posted by: EJS on 23 April 2011
Hi all,
Does anybody know how we can upload information into the Naim music database? The question came up when I was ripping Karajan's classic account of Bruckner's Symphony No.8, and the HDX recognised the disc as Dino's 'Just Piano... Praise'!
Hello EJ
From The HDX manual:
AMG:The All Music Guide database is the primary database that the HDX-SSD interrogates when a new CD is inserted in its drawer. The AMG database can be interrogated manually at www.allmusic.com
Note: The data provided by AMG is occasionally inaccurate or incomplete. It is possible however to submit corrections at www.allmusic.com
It appears to be a manual operation though – Take a look here.
http://www.allmusic.com/contact/corrections
Painful!
Peter
EJ……Could not agree more with your conclusion; seem likely to be a complete waste of effort in fact.
Peter
Well, filled in the form just in case - perhaps AMG will pick it up.
I have ripped over 2500 CD's and had 5 with incorrect data. I simply amend the data in the Music Store with the rename facility.
Gerry
Of course, but that solves only the important bits - the extended metadata remains associated with the wrong discs.
Hi,
I am missing out - how do you access this extended metadata?
Gerry
Ah, that explains it there, is not normally much info re performers on my music, and I do not use nserve, just DTC and my associated Music collector database, to which I have continually added data from AMG whenever I bought CDs - frequently.
EJS,
If you have the Naim rip on a remote store you could copy the files into a network share, so that you have full control over the metadata - then delete the album from the store.
NOT a good solution though. Be better if Naim gave users some control over what is in their database.
M
