Suggestions for speaker cable
Posted by: Paul Rodgers on 29 September 2015
NACA5 is good value and lots available second hand,also people rave about Tellurium Q Black, but its not cheap.
Karl
The Chord Leyline is a bit skinny at 1.3mm/2, so I would guess most other cables would be better.
Don't go mad, TQ Black is nice, but a 5m pair is over half the price of your speakers. I would consider the TQ Blue variants as a possible alternative.
NACA5 is a good cable & for a Naim system we all know you can't go wrong. Problem is its very stiff & needs to be worked on with a hair dryer if you want it to lay & stay neat & tidy. Re tidy - Chord make very well behaved cables with their non-screened models, I've got Odyssey & it bends & stays in place as good as any cable, & Odyssey or its baby brother Rumour is another suggestion.
I had the same system as you at one point buut with different speakers and I also originally used Ley line 2. I can confidentally state that you will hear an improvement moving from the Ley Line. I went to Chord Oddysey which was much much better and then TQ Black which is fantastic.
thanks everybody , my dealer is advising the NACA5 or to save money chord rumour 2 , looking like the leyline was very budget cable so any upgrade will be a huge improvement !!! anybody used the chord rumour 2 ? take care Paul
I used Chord Rumour 2 but not on a Nap100. Compared to the Ley Line it gave more scale and detail and improved bass. The Oddysey was much better but, as you say, it will give a improvement over your Ley line.
Hi if i go for the NACA5 then i only need 2m each side , do i really need to spend the extra £90 on the extra 3m that naim suggest ?
take care
Paul
Agree with ChrisSU and Timbo39 - 3.5m runs of NAC A5 is the way forward.
Try Chord Odyssey MK11
What about Teddy Pardos cable? Anyone tried this?
Paul Rodgers,
Are you the same guy from Free and Bad Company?
Hi, can you kindly recommend a length for the chord or TQ? Don't need more than 1.5m for each but too short doesn't seem to be recommended in general? Thanks in advance
