nac 202
Posted by: Aceone on 05 October 2015
hi everyone if i was to upgrade from a hicap dr to a supercap to power my nac 202 is there a big difference is sound quality, thanks aceone .
A much better use of funds.
i take it the 282 is much better than 202 scooot
i think i will stay put for now and get a nac 282 at a later date thanks for your answers .
Aceone, you have to audit the 282 before you buy which presentation is totally different to 202.
202 with 2nd PS upgrade would be an even more gilded turd, but the same turd right? ![]()
Turd used loosely as the 202 may be where I land first if I go separates...but the end goal is 282 for separates (for me)...IF I ever separate.
which power amp do you use? Which speakers? Which source?
Supercap DR will give you much temptation for a NAC 252.
I think 202/HCDR is really quite good if -
- the source is excellent,
- if NACA 5 speaker cables are used (terminated properly at both ends, no strands of copper missing)
- if Compatible speakers are used (ask Naim HQ directly which ones these are)
The usual suspects are Naim speakers including Ovators, Dynaudio, PMC, Focal, Neat and Kudos.
Good luck, whatever you do.
Nick
Agree with suggestions above. Aim for the 282 first, and stick with your Hicap for now.
