Alternatives to Finder on the Mac?
Posted by: Jan-Erik Nordoen on 06 October 2015
Has anyone found a straightforward alternative to Finder on the Mac? Perhaps I'm just an Xtree nostalgic, but the way that folders are structured in Finder just seems counter-intuitive, as it hides the tree structure.
Thanks for your help,
Jan
Posted on: 07 October 2015 by winkyincanada
You'd perhaps be better off posting this on a Mac Forum.
Posted on: 07 October 2015 by Jan-Erik Nordoen
There's another forum out there ?
Posted on: 07 October 2015 by Derek Wright
Take a look at this site - it list a large number of applicatiions
http://download.cnet.com/mac/?tag=bc
alternatively ask Google for a Finder replacement
Posted on: 07 October 2015 by EJS
Mucommander, a free Norton clone, has been a long standing favorite, but requires Java to run. Commander One has just been introduced, seems to be similar in scope, but entirely coded in Swift and should therefore be much faster.
Posted on: 08 October 2015 by Martin Zero
Jan
What can't it do that you need? I find it better than anything
Posted on: 09 October 2015 by Jan-Erik Nordoen
Perhaps it's simply old habits dying hard, but ideally I would like the tree structure to be visible in the left hand 'Favorites' pane.
I've downloaded TotalFinder, which is a Finder plugin and goes someway to a clearer view of my files, by adding Chrome-like tabs across the top of the page.
I'll look at Mucommander.
Thanks for the ideas,
Jan
Posted on: 09 October 2015 by Martin Zero
Hey Jan, this not "tree" enough?
Hi Martin,
Aha, Xcode. Is this only for developers, or can mere mortals use it without damaging something?
Jan
Posted on: 10 October 2015 by Derek Wright
That is a display of the Xcode tree using Finder.
You can add extra directory names to the left hand column (Favourites)  so that you can go directly to a subtree or folder directly.
Posted on: 13 October 2015 by Jan-Erik Nordoen
Ah, of course. Rather obvious now...
I'll stick with Finder and the TotalFinder plugin.
I must say that the Spotlight search tool is incredibly fast and accurate, ultimately more useful than Finder.
Thanks all for your help.
Jan
