Looking for a DAC
Posted by: nao on 07 October 2015
I want to buy a DAC to connect PS4 up to my pc monitor. I needed to convert the digital sound from the ps4 to my standard 3.5mm jack speakers. I saw a convertor in amazon But I want it powered by USB, any recommendations? All help would be appreciated.
Moderated Post: Link removed. No unauthorised links in the Hifi Corner, thanks.
I have also used the Audioquest Dragonfly .. It's quite good and certainly massively better than the internal DAC in my Macbook Pro, but if I am honest I wouldn't really call it hifi, and I actaully think the DAC in my iPhone 6 is better, but for gaming I would have thought it be excellent.
Simon
You can try the Meridian Explorer. It has 3.5mm electrical and optical S/PDIF output as well as 3.5mm headphones output. Best, nbpf
Blustream do a couple of different products that will do what you want, the HD11AU will De-Embed and convert to Analogue stereo from an HDMI source, or the DAC11AU will convert to Analogue stereo from digital coax/toslink.
They are 5v DC and come with a power supply, but at 1A current draw you could potentially modify a USB cable to power whichever you choose...
Not too sure how available these are for you however.
Simon
Actually, Simon, you have a point - I've recently splashed out on a decent pair of earphones, which are much more revealing than any I've used before, and they do show that the iPhone 6 isn't all that bad. Not quite sure if it's better than the MBP/Dragonfly, but for a phone (which I'd written off because it's a phone) it's quite respectable. Not that this helps the OP, but he seems to have vanished.
