Pro-ject Turntable with Naim System
Posted by: marcobb on 08 October 2015
Hi Folks,
Any comment for the pro-ject xtension 9 turntable with Naim System ?
marcobb
Hi - a Project TT would be fine depending upon the Naim components you were matching it with and most crucially the cartridge and phonostage you intend to use.
What amp do you have?
Hi,
I am using Stageline-N with Hi-Cap DR, 282/Hi-Cap DR/250.
And current i have the Ortofon 2M Black cartridge on hand.
marcobb
Thanks Magnus ~~~
mmmm, am not so sure, your system is really good and will show shortcomings of a less than top notch analogue vinyl spinner. That said, you have to start somewhere... And it's a lovely thing spinning the old black discs.
regards
ingenius
