Superuniti Problem.
Posted by: mikeybaby on 11 October 2015
When the Superuniti is idling, and regardless of volume I hear a distortion through my speakers intermittently...i hear shhh then silence, then shhh..then silence and it is more prominent-- then less prominent...in left channel then later both channels. Finally I put the headphones in and no distortion..whats happening here? Please and thanks.
Posted on: 11 October 2015 by hafler3o
Sorry no idea. You have tried powering off for a few minutes, factory reset etc?
Posted on: 11 October 2015 by CariocaJeff
Used to get such noise through my last system. Wondered if was picking up some radio interference somehow through the cables. It seemed to be more prevalent in the evening than during the day, and  eventually just disappeared.
Posted on: 11 October 2015 by mikeybaby
I will try a factory reset...but I think its RFI.
Factory reset--Problem solved. Thanks!
