Ovator S400?
Posted by: kaydee6 on 14 October 2015
I am looking to move from harbeth shl 5 to Ovator S400. The S400 is to be driven by a Supernait 2.
My only concern is the room is a 4.5m wide by 6m long. The s400 will be 1m from the rear wall, 0.5m from side walls and 1.4m from each other.
Is 1.4m from each other too close to for the S400? Any practical experience from the friends here?
Posted on: 14 October 2015 by Kiwi cat
Hi kaydee6, your room seems quite large so why would the speakers be so close?
Posted on: 14 October 2015 by nbpf
How do you arrange the S400 to be 1.4m apart from each other and 0.5m away from the side walls in a 4.5m by 6m room? If you have them along the shortest side and 0.5m away from the side walls, I would expect about 3m between them. I have the S400 in a similar room, about 3m from each other, 0.7m from the side walls and 0.3m from the rear wall and they sound great. Best, nbpf
Posted on: 15 October 2015 by kaydee6
Sorry, I think I was too generous with my room size.
It should be 3m wide by 6m long. This ends up to about 1.4m between the speakers. Is this too small?
Posted on: 15 October 2015 by rackkit
Might be easier to help you out if you can post a diagram or photograph of your room layout and current speaker location...
Posted on: 15 October 2015 by hungryhalibut
Surely your Harbeths are in the same position. Do they work ok?
Here are the pictures of the room with the Harbeth SHL5.
https://www.flickr.com/photos/...05295/in/dateposted/
https://www.flickr.com/photos/...91241/in/dateposted/
I believe Ovator S400 width is the same as the SHL 5.
Around 33cm.
Posted on: 15 October 2015 by hafler3o
Why are you changing, the move seems to be a side-grade at the very best? Also try positioning your speakers using the Cardas system, you seem to have the room, google it
i want more prat maybe?
Posted on: 15 October 2015 by rsch
With such a wall size ratio of 1:2 I' d try them on the longest wall.
Roberto
Maybe? What we want and what arrives maybe two different things!
Roberto
That would have been my next suggestion, I have a slightly narrower and considerably longer listening room so needed to tackle the room acoustics. I have a feeling a speaker with a smaller volume might be better given that intrusive wall unit near the left speaker.
haha, agreed.. but that's the fun part of an audiophile life. No?
.. But that's the fun part of an audiophile life. No?
I'm more of a "glass half-stolen, half poisoned" guy
I'm more concerned about grotesque soft toys and the wire.....
The soft toy helps with the sound treatment
Posted on: 15 October 2015 by Bart
In and of themselves they are rather innocuous.  But the juxtaposition is disturbing.
