Superuniti Question
Posted by: mikeybaby on 15 October 2015
How do I go from analogue 2 to analogue 1? Going from 1 to 2 is easy you press the input button...but to go from 2 to 1 do I have to go through the all inputs..? analogue 2,3 digital 1,2,3,4 etc..etc..? this is time consuming and doesnt make sense. Please advise.Thanks.
Posted on: 15 October 2015 by Donkeyhaute
Hi. You can re-map the remote control's input buttons in the settings menu to whatever you like.
Posted on: 15 October 2015 by hungryhalibut
You can switch off the ones you don't use, which improves the sound and makes everything much easier.
Posted on: 15 October 2015 by mikeybaby
Hungryhalibut...I looked through the manual and cant understand how to switch off unused inputs...please help.
Press spanner, inputs, then disable unused things. Also disable digital out.
Just press the little arrows and you can enable or disable inputs. Once disabled they don't show on the app, which makes it tidier, nor do they appear as you cycle through inputs with the remote.
Does shutting off inputs not being used really improve the sound?
