Severe issue with my muso
Posted by: Vesa on 17 October 2015
Hi, first of all I would like to thank Naim support (Mark) for patiently trying to help me out.
I uploaded and installed the latest software version with Tidal support on my muso. After the update was completed I can no longer use muso wirelessly. Weather using IPhone or IPad (and Mac), the Airplay connection attempt fails every time. IOS actually shows muso on the Airplay speakers list, but can not connect and gives me "unexpected error" message.
I have tried quite a few tricks:
1. 1 sec and 6 sec resets and power down, no luck
2. I set my Apple wireless so that all devices used 2.4GHz with no luck (see #1)
3. I shut my other Apple wireless router and carried muso close to the main router, with no luck (see #1)
4. installed old version of firmware over ethernet connection from my Mac, same problem
5. I bought the Net Analyser sw. I have booted muso, done 1 sec and 6 sec resets, but the scanner does not show muso on the device list at any stage.
I am inclined to think this is a hardware issue. Funny it happened at or right after muso sw update.
Any more tips for me? Or should just carry muso for warranty repair?
TIA
Vesa
The only changes in my environment since I last upgraded muso sw are: IOS 9 upgrade, El Capitan for my Mac. That's it.
