Can't get iRadio or Tidal to stream
Posted by: Graham Clarke on 17 October 2015
For iRadio when I click the icon it says "connecting..." but never does and eventually times out.
For Tidal, I can see and search for albums/artists/tracks etc via the Naim app, but when I select Play there's a long delay before it says "Can't play" presumably when it times out.
I'm using BT Infinity 2 via BT Home hub 4 which has most recent firmware.
My NDS is using wired Ethernet to a Netgear 108 switch in my lounge. It's configured with a fixed IP address (so DHCP disabled). This in turn is connected to a Netgear 116 hub upstairs my in office. The 116 hub is connected to the 1 gig port on the Home Hub 4.
The HH4 is also enabled for wireless and there is a second wireless network connected to the 108 switch. However, given everything for music playback is wired this shouldn't be relevant.
Playback from my NAS drive (also connected to the 108 switch) is rock solid without any problems.
I've also confirmed that there isn't a fault with the NDS as iRadio worked fine on it at UHES. So I'm suspecting it is a network issue of some description but am stumped where to look next.
All suggestions gratefully received!
Graham
PS: I did also try emailing Naim via their support address a week ago and didn't even get a reply...
