Tidal - quick question
Posted by: John3 on 17 October 2015
As part of the download process I was invited to download the Tidal app to my iPad which I did. Is this actually needed though or is everything done through the Naim app?
Posted on: 17 October 2015 by ChrisSU
You don't need it to play through your Naim streamer, just go to the Tidal input in the Naim app. Handy if you want to use Tidal elsewhere though, e.g. while travelling with iPhone or iPad.
Posted on: 17 October 2015 by John3
Cheers, as I suspected
