Shelf help please
Posted by: AndyP19 on 20 October 2015
Just taken delivery of NAC 252/Supercap/NAP300DR to partner my ND5 XS +PS and Musical Fidelity A3.2 which as you can see (hopefully picture attached) all are sited on the woefully inadequate Danish teak coffee table!!!
I was looking at the Naim Fraim positioning two side-by-side (circa 130cm) but the dimension of my alcove space is 112cm which limits me and I really don't want to stack up vertically (using one unit) if I can avoid it.
Any ideas?
Thanks Andy
Posted on: 20 October 2015 by ChrisSU
When I looked at dimensions of various racks to fit in a small alcove, I seem to remember that Hutter was the narrowest. I don't have the info to hand, but you can get the dimensions from their website. I'm fairly sure you'll be able to fit two of their racks side by side in your space.
Posted on: 20 October 2015 by hungryhalibut
You can get Hutter racks in 500mm width, so two would fit perfectly, with space at the NDS for the wires.
You can also get the Quadraspire SV2T, which would be my choice, which is 1105mm wide. That would look better than two Hutter racks, and is more easily available. The bamboo version works really well.
Posted on: 20 October 2015 by Sounsfaber
You mush do something, even bricks. Your going to be amazed when you get it sorted. Nice system enjoy.
Posted on: 20 October 2015 by naim_nymph
2 x naim fraim racks may just fit...
if you positioned one rack back-to-front (for the power supplies)
Would be very tight though with 112cm,
if it does actually fit (?)
