Noise from Stageline/Supernait
Posted by: sjostrom on 22 October 2015
Hello, I just purchased two pre-owned components, a Supernait 1 from a private seller here in Sweden and a Stageline N from en English company. The SN performs without issues when I use it with a Apple TV. When connected to the Stageline i get a sound that could at best be described as "the sound when you put the need down on the record" perhaps slight more rumbling ans scraping. The sound scales with the volume and it's only in the right channel. It's not constant and sometimes I can get a whole listening session in without it happening, sometimes it goes on for a long time.
The SN and the TT is both connected to the same Musicline and I have tried switching the phase. The Stageline is powered via Aux 2 on the SN. The sound also persist even if I disconnect the TT from the stageline. I have also disconnected the Apple TV. All cables are separated from each other and I have tried moving the equipment around as well. If I disconnect the Stageline the sound disappear right away.
I have tried reaching the company I bought the Stageline from without reaching them and the guy I bought the SN from hasn't used Aux 2 (he saids).
What do you think should be my next step? How can I at least narrow the problem down to the Stageline, cable or SN and fix it?
Thank you in advance and BTW, when the noise isn't there, it sound just lovely! ![]()
