What is the "actual" bitrate?
Posted by: BigH47 on 30 October 2015
This may be another dumb Howard question, but how can one see what actual bit rate/depth is being played?
In my set up MacMini-2Qute-52 after setting up iTunes in AudioMidi to say 192 K 32bit 2Qute shows the blue light for 192k all the time regardless of what level of music is being played.
So is there a way am I able to see the actual bitrate/depth as music is playing?
Posted on: 30 October 2015 by Steve J
Hi Howard,
Are you still using Audirvana? If so that should bypass the Audio Midi settings of iTunes and the light colour on the 2Qute will indicate the bitrate. I have the iTunes Audio Midi setting at 16/44k, but it's academic really as I use the Audirvana. For hi res files I come out of iTunes Integrated Mode and drag the files into the Playlist box.
Steve
Posted on: 30 October 2015 by BigH47
No Steve I haven't tried Audirvana yet, I was waiting until winter, something to do on the dark days.
We will have to have another chat soon.
Posted on: 31 October 2015 by garyi
Install bit perfect, they have updated recently to address a few of the issues it had, but basically it will switch audio output on the fly depending on the file type.
Posted on: 31 October 2015 by BigH47
I did briefly try V3 of Bitperfect, but couldn't get any output. I will try it again later.
