Which interconnect for PhonoPre into SN2
Posted by: Checkthisout68 on 01 November 2015
Hi, I am looking for a recommendation to connect my Rega Aria PreAmp (RCA out) with my SN2.
I am currently using a Phonosophie RCA to DIN5 cable, which is not too bad. I was thinking about Hi-Line RCA to DIN5 cable but maybe you have other / better suggestions. What about the SN2 Cinch / RCA inputs? Are they considered as good as the DIN inputs? Because then I could be looking at a wide range of cinch cables.
Suggestions welcome! Should be high end, otherwise I can stay with what I have got.
Best
Chris
Posted on: 01 November 2015 by b_lund
Not sure if its considered "High-end" but the original Rega Klotz RCA/RCA or clones of this is superb
Posted on: 01 November 2015 by George F
The standard Lavender interconnect cable is available [from Naim via your retailer] with a pair of RCA phono plugs on the source end, and at a price that balances the electronics, and some people including me think the Lavender is all you really need.
ATB from George
Posted on: 01 November 2015 by Checkthisout68
Thanks, what about Rega Couple 2 RCA/RCA using the SN2 RCA -in ?
Posted on: 01 November 2015 by The Strat (Fender)
Chord Crimson RCA>DIN?
