NAP 250/300 third party DIN XLR
Posted by: analogmusic on 08 November 2015
Does using one of these on a NAP 250 or NAP 300 void the Naim warranty?
Posted on: 08 November 2015 by hungryhalibut
I hope not, as I use one!
Posted on: 09 November 2015 by analogmusic
The DIN-XLR does not carry any power, just the musical signal so I think it should be treated as an interconnect.
What is the official view on this though from Richard Dane
Posted on: 09 November 2015 by Richard Dane
It doesn't carry any power so it shouldn't be able to cause damage if it's not done right.  Ergo, use of such a thing would probably not constitute "abuse" of the amplifier.
Posted on: 09 November 2015 by Claus-Thoegersen
Discussion of the hatpin and Chord din xlr cables have never  been closed on the forum, this should mean that all is ok. This is a regular signal cable just with another plug in one end.
Claus
I do see some modestly priced alternatives to some really expensive ones
but do they improve on the Naim supplied one in the box?
Posted on: 09 November 2015 by Zeny
I'm using chord signature tuned aray din to xlr. They work great.
Well, I guess the standard DIN-XLR lead can be improved on, as shown by Naim's Super Lumina and also perhaps (according to some - I have not tried) the Chord TA.
I have tried some more affordable alternatives and none eclipsed the standard lead in my opinion. I indeed, they all tended to lose something quite fundamental, often making things somewhat smoother, yet also making things too soft and lacking in tension.
I also remember listening to some alternatives and prototypes at the Naim factory.  I recall that we had got a Hi-line suitably made up for the task.  It was comprehensively trounced by the standard lead.  Which I guess just goes to show how important it is to design a cable specifically to a particular task - you can't just throw any cable in there, no matter how "good" it may be in other situations, and expect it to work brilliantly.
I'm using a pair of VDH First Ultimate RCA interconnects to connect my streamer to preamp. They are relatively affordable and pretty much trounced the standard lavender din interconnect. I think the standard cables included by Naim work pretty well and do the job, but if you have the budget, there are certainly better alternatives.
Posted on: 09 November 2015 by tonym
It's well worth trying alternative DIn-XLRs. I made up my own, mainly because the standard ones are too short when you've got 500 amps & need to route the cables around the rear heatsinks then into a SNAXO. Having done so, I found they sounded considerably better than the standard offerings (after running in).
Posted on: 09 November 2015 by Graham Clarke
Although signal interconnect cables can still cause damage.  I know of at least one case of a broken Hi Line causing preamp damage.
hi-line causing amp damage? what did it damage and how?
Posted on: 09 November 2015 by Ravenswood10
I'm using Chord Indigo Plus between my Supercap DR and 300DR and am really happy. Nothing has blown up yet!
