Tin Ears
Posted by: andrewnielsen on 09 November 2015
This is no good at all. I went and listened to some DACS... the differences between the Audiolab, April Audio Eximus DP1 and DAC V1 were pretty clear. When I went to compare my own Xindac DAC-5 to the DAC V1, I couldn't tell the difference! The Naim DAC had never been plugged in before and had warmed up for 15 minutes, so maybe that made a difference. I was listening to Queen's Greatest Hits. Amp was a Naim XS and the speakers were Quad 11Ls. I got the dealer, Caxton Audio Brisbane, to stop using those vile, shrill Nordst Silver speaker cables and he used ? DH Silver Sonic cables. Hopefully the problem was that I was too familiar with the sound of the Xindac. I will compare it to the Chord DACs. If I can't tell the difference then, then I'll be able to draw a line under this hobby. Maybe I should borrow one and see if I can tell the difference. No point doing that yet as the reason to visit the dealer was that the Quad 11L active speaker was making popping noises.
Just to clarify, this is my office system I'm talking about. The specs below are for my home system.
Posted on: 09 November 2015 by feeling_zen
That's a nice main system you have there. I have almost the same setup in the upstairs bathroom
Posted on: 10 November 2015 by Steve J
That system must have a clean sound zen.
Posted on: 10 November 2015 by Allante93
Especially with that new snaxo 363!
Posted on: 10 November 2015 by Foot tapper
Andrew
before you finally give up on this hobby, I recommend that you try a portion of your country's special kimchi.  It goes especially well with the 1 month old, air cured, catfish sashimi that normally accompanies it.  Mmmm, lovely.
It will sure blow any wax out of your ears to give you a cleaner, clearer hearing experience.
I trust that this helps you a great deal.
Best regards, FT
Posted on: 10 November 2015 by feeling_zen
I wouldn't say that but it has some real grunt. At least, I think that sound is coming from the system.
Posted on: 10 November 2015 by hafler3o
Why talk about the rubbish system when you could be posting a pic or two of the 'half-decent' one.
