AV2 strange behaviour
Posted by: Occean on 15 November 2015
I'm short - my AV2 is only using my sub if, on the AV2 it's turned off (!!) and a digital input is selected. If multi in is used the sub doesn't work if set to off or on (yes the bluray player is set to on)
Any thoughts? And yes...it only works set to off! Using a thx test tone as a test.
Posted on: 15 November 2015 by rackkit
Very odd. Is there anyway to do a complete reset of the AV2?
Posted on: 16 November 2015 by Occean
On reflection this makes sense....when I 'turned sub off' on the AV2 - the bass routes to the main speakers which is connected to the sub (REL dual wiring)
So it must be a cable or sub issue.
