Wifi problems on SWMBO's Windows 10 laptop
Posted by: Dungassin on 19 November 2015
Well, I think SWMBO's 5 year old Toshiba laptop (now running Windows 10) is dying (sigh).
I had to sort out a connectivity problem for her earlier on this evening.  It wouldn't connect to our BT Homehub 5 via wifi.
First thing I did was to try to re-establish the wifi connection.  It woudn't!  So, tried my iPad and iPhone. Wifi working OK on them.
Switched router off/on, and restarted the laptop.  Still no joy.  Then noticed Norton 360 didn't seem to be working either.
SWMBO then complained that some of the keyboard keys didn't seem to work properly either.
Eventually gave up & went into the loft for a long ethernet cable and got her up and running with that.
Looks to me as if the laptop has had it, and that the wifi adapter  (although it 'sees' our Homehub) has died.  So, I suppose I shall be off out with her soon to get a new laptop.  Don't want to spend too much, as all she uses it for is internet and email, plus looking a photos.
Unrelated, but I am in the process of updating the metatags on a LARGE collection of compilation disc FLAC files.  I read the recent thread in 'Streaming Audio' on metatags and compilations, and would report that I have in the past tried every one of the solutions to see the artist on an individual track (except that of adding the artist name to the title), and NONE of them work (Asset upnp on QNAP NAS)
So, that's a task is taking a few days of intensive typing.   This revealed another problem.  I am modifying the files on the QNAP NAS directly, mainly using MP Tag Editor on my Mac as the Tag editing bit of dBpoweramp is not very efficient when doing this on the Mac.
All was going well and after about 50 album I backed up to USB 3 external hard drive using Chronosync (a bit like SyncBack Pro on the PC), and that went OK.  However while doing the next 50 albums, Finder seemed to be getting increasingly slower at accessing my NAS, and MP Tag Editor was getting noticeably slower at writing the updated files back to the NAS.   When I eventually got round to doing the next Chronosync Backup (I suppose I should really say 'mirror', as I am doing that rather than just backup or synchronisation), the transfer speed was report as only 1.45mb/sec!  It took several hours just to do the 50 album 'mirror'!
Sat back and had a long think.
First things tried - check transfer speed to my other NAS - also slow, but a little faster.  Restarted the Mac.
Second thing - started up Bootcamp and played around on the PC side.  NAS drives were a little faster, but still slower than I remembered.
3rd thing - did a websearch.  As my Mac has ALWAYS been slow at opening my NAS drives in Finder, cleared the cloudd caches as suggested, which speeded up the Finder access to the NAS a little.  Didn't cure the slow write speed to the NAS.
4th thing.   Restarted the router - didn't cure it.
Solution?  Eventually reset the Router to its Factory settings.  Transfer speed using Chronosync now running at 22.8 mb/sec.
Arn't computers a PAIN?
Posted on: 19 November 2015 by Clay Bingham
Yes they are. In terms of music files they are still relatively crude devices with all sorts of connectivity and stabilty issues. In a few years we'll laugh at what we used to go through to manage our music on computers.
Posted on: 19 November 2015 by Dungassin
Just done a bit more online research.  I know that there is a wifi connectivity problem with Windows 10 upgrades, but SWMBO's laptop has been OK with wifi for a few weeks now, and this problem has arrived de novo.  I did remove the old VPN drivers before erasing and reformatting her hard drive not long after she did the upgrade, as her computer had become rather slow and unreliable (not recognising USB sticks etc)
I'll have to try the solution suggested (basically editing the Registry and removing old VPN drivers if they have somehow managed to get reinstalled) tomorrow, but am not hopeful.
Posted on: 19 November 2015 by Huge
Try using a separate unmanaged switch to separate out your wired internal network traffic, they are much simpler and tend to 'just work'.
Broadband routers usually have all sorts of odd extraneous stuff like firewalls that can do odd things like tying up the router's processor.  These additional functions can slow down with time as additional rules get added and other settings get changed away from optimal.  This can sometimes account for why a reset speeds things up again.
Posted on: 20 November 2015 by Dungassin
Thanks Huge.  It would appear that my NAS drives are connected via the router, but to fix that would require getting the engineer back to re-route the cables.  To explain : router in living room, has 4 GB ports.  One goes to a seven port Netgear Switch.  The others immediately go into a conduit and up to my study.  Of these, one runs to a 5 port Netgear Switch, which supplies my Mac, NDS and various other odds and sods.  The other 2 continue in a conduit through the wall into the adjacent bedroom where the NAS drives live.  (didn't want them in the same room as the NDS system).
That's the first time I've had this slowing down problem.  The Mac slow Finder problem has always been there, and is a known problem for many. (check the Apple Forums)
As regards SWMBO's laptop?  Well, I did the Command Line bit and deleted the suggested registry, and she has her wifi back.  Don't know why she suddenly had this problem.  Perhaps Windows 10 had an update which caused it?   I'll try to persuade her (again) that she'd be better off with an iPad for what she actually does, especially as she is a one-finger typist, but am not holding out any hopes of succeeding.  (sigh)
Posted on: 20 November 2015 by Huge
Since the ports of your router are only ever connected via switches (none of your devices are connected to the router directly) then the network traffic side of the router (i.e. the switch side of the router) cannot have been the problem.
Without knowing your router config I can't know what happened and what changed when you did a a full factory reset of the router, but here is a possibility...
Could your DHCP setup have got out of sync?
Multiple devices with the same IP address on a network can cause all sorts of problems, and a full reset of the router would force a network wide refresh (as the DHCP server would have been re-initialised).
The Win10 WiFi problem could also have been caused by a piece of application software, either due to an incompatibility with Win10 or via a bug.  Maybe an application claimed it could speed up her computer and would she like it to do it?  Maybe her anti-virus offered to increase her security?  Unfortunately there's soooo many possibilities!
As the Mac issue, I don't use Macs, I find it difficult to work with their habit of hiding the details, as this makes it much harder to diagnose faults (I'm a computer techie).
Posted on: 20 November 2015 by Mike-B
Interesting   .....  but .....
.....  I'm not convinced this is a Win-10 issue or that its only because of non-standard settings on the BT router
I've got a Dell,  it came with Win-8.1 & is upgraded to Win-10
My wireless is 101% OK,  its instant, by the time the screen has come on its already connected.
Her Ladyship also has a Dell, its about 3 years old & came with Win-7 & its also now on Win-10, its wireless connection has always been slow, but compared to the old Dell I had at the time it was no different so we were not too concerned. Compared to my new PC we now know her wireless is slow to load, it does get a connection, but takes 30 seconds or more to make it.
My PC see's & displays my own router & its WiFi-X & FON & the one (nearest) neighbour.
Mrs-Mike's PC see's the whole neighbourhood - I too can see them all with my wifi detector app, but my PC does not,  seems like it has a low signal strength detector/rejecter.
My PC has an Intel Dual Band wireless adapter,  Mrs-Mike's adaptor is a Dell adapter & I have a feeling this is the difference in my case.
My BT-4 has a number of non-standard settings including fixed wireless channels on both 2.4gHz & 5gHz & static IP addresses,  it works perfectly for me,  however if what you've done has fixed the problem = great.
The Windows 10 wifi problem was solved by double checking that old VPN software had been deleted, and then editing the registry to make sure.  The details of how to do this are easily available via the web.
SWMBO doesn't really understand computers, and as I have said in other threads, I take her laptop away from her every couple of weeks and remove adware etc, which she keeps managing to reinstall!  I might add that she always expects me to drop everything and sort it out for her whenever she has a problem.
I know what you mean about Macs.  I moved from PCs to the iMac because of various problems, and because I wanted a larger screen than my Windows laptop, which makes it much easier to use Sibelius Music Notation software (IMO), but I didn't want to have my Windows laptop connected to an external screen, or go back to banging my knees on a Windows Box sticking out of the front of my desk.  The iMac does have the advantage of a small desktop footprint.
Overall I've been far from impressed with the so-called greater ease of use of Macs, and the fact that Safari (Mac Browser) sometimes seems to stall when downloading a webpage.  This has sometimes been so bad as to require restarting the Mac.
However, I am becoming quite adept at solving Mac problems (which have been many, especially since the advent of El Crapitan (no, that isn't a typo), but then again I am not very impressed with Windows 10 either so far..
Posted on: 21 November 2015 by Dungassin
Well, last night SWMBO's laptop decided to lose it's wifi again, and this time even her ethernet connection was flaky.  On my iMac at about the same time, it was very slow while trying to access a webpage via Safari, then Safari window changed to show a message from BT saying 'no broadband connection'.  This resolved after a while. (a couple of minutes?)
Tried to access the Hub's homepage, but it wouldn't accept the admin password!  Yes, I did double/treble check that I was entering the correct one and that I hadn't inadvertently switched on CAPS LOCK!
To solve it all this morning, I had to do ANOTHER factory reset of the hub (to get back access to my admin password), and then redo the registry edit bit on her Windows 10 laptop.
I'll give it a day, and if the problems persist I shall probably be chasing BT for a replacement Home Hub 5.   This reminds me of why I went from a Home Hub 3 to Netgear N600 3 years ago.
What really annoyed me above everything else, was having to go through the 'smart' setup routine on the homehub again from every device (iPhone, etc) using its wifi, and had to reset the link for the Netgear Wifi extender.
Posted on: 21 November 2015 by Derek Wright
Hugo said
"(I'm a computer techie)."
and yet you are not at home with Unix or it's derivatives - shame
Posted on: 21 November 2015 by Huge
Are you refering to me?
I learnt to use use Unix on a SCO system about 25 years ago when I was a systems programmer and system admin.  My NAS runs a version of Linux, and I use Ubuntu in a VM.  Just because I dislike the Apple corruption of the Unix concept doesn't mean that I'm averse to Unices (and functionally related systems like Linux) as a whole: they have their place.
