Install advice
Posted by: Graham Clarke on 26 November 2015
Have just taken delivery of a Powerline. Please advise whether I should wait for my dealer to install or whether I should have a go myself? Is it a tricky task, as they didn't supply install instructions ![]()
Graham, shouldn't this be posted in the padded cell...?
I see the exploding sausage found a use though, so not all bad...
Is it directional? How do u know which way it goes?![]()
david
Possibly, but as a leg pull on the 500DR thread the same place seemed logical. Feel free to move if you so wish.
i know above is probabaly tongue in cheek, but there are actually quite a few dos and donts when installing powerline - ensuring secure/firm connection, dressing etc.
Extra level of difficulty if Fraim has no Fraim-guards -- as in "the case of the disappearing balls" -especially if you are installing on 500's!
Also old age complicates things a bit... :-)
But once you master the technique -- plain sailing!
But you know all this already anyhow....
enjoy
ken
enjoy
ken
Honestly Ken, letting the facts get in the way of a good leg pull! ![]()
Well, quite honestly, if you can afford a Powerline you can afford to get someone to install it for you. What are you whinging about man? Grow a pair.
Ooops, sorry... a sense of humour was never my strong point. ![]()
enjoy...
ken
Did you install your new 300s Graham? If so you should find the Powerline a doddle. ![]()
Hungryhalibut will do that for you for a very reasonable £400 per hour.
Hi Graham
I always ask my National Grid dealer to install Powerlines.
It gives the cottage a much better continuity of electricity, especially after stormy weather.
I think he's charging £800 per hour now, so for £400 he can only half install it
Mr Clark
I hope you only have the "one" Powerline to worry about ?
Here's a pair I grew just for you, Harry.
Good grief no! My dealer did that when he delivered them.
Honestly, where's HH when you need him? I'm not sure I can stretch to £800 for install though. Maybe he could install one end of it for £400? I've found my club hammer so think I can install the other end myself.
If it won't got into the DIN socket try sawing off a pin or two, I'm sure they're not all required.
That's more like it!
