Problem Solved (Finally!)
Posted by: thirty three and a third on 30 November 2015
Some of you might remember I was having a problem with the artwork not showing up on my iPhone/iPad while listening to my files. https://forums.naimaudio.com/to...issing-album-artwork
After much trial and error, as well as using the suggestions from this forum (thanks, guys!) I've got the failsafe solution for any of you out there using a Synology BeyondCloud server loaded with AIFF files.
- Use Metadatics to fill in the missing artwork. Time-consuming if you have a lot of files like I do, but I'm sure it would have been much worse if this program weren't around. Well worth the money.
- Re-index the server. Let it figure out what the hell you just did to it.
- Re-boot the server.
And there you go. If this idiot can do it, so can you!
