DAC V1 intermittent mute
Posted by: Adi Stefan on 07 December 2015
Hello,
I have DAC v1  for 8 months , and i have the next situation: for the past few days i saw the dispaly became little bit darker on the top front(first 2 lines), and the unit automatically mute, sometimes it takes longer till first automatically mute but after first auto mute it become intermittent . I tried reset, update firmware to 1.16, stop/start, push logo for unmute, unmute from remote control...same situation every time. I use as sources toslink (TV) and mac mini (USB); the situation is  more often on toslink input(TV),  soruces (tv and mac) are on togheter all time, mac mini is connected through HDMI at tv...
If i use dac v1 with fixed output, its ok but still try to mute because every few seconds on display is showing volume fixed, as he try to mute.
Can anyone give an explanation on whats happening with my dac v1? It is normal, it's something i miss with dac v1 inputs.
Thank you.
Posted on: 07 December 2015 by Jude2012
I think that this may be a hardware issue.  I had a similar issue about in the past.  It was a fault with the switch that is embedded in the logo.  The switch was replaced.
In any case,  I would bet your V1 checked out via your dealer and Naim.
Jude
