Plugplayer type app for a Mac
Posted by: Paul Hannan on 15 May 2011
hi, I use plugplayer at the moment prior to getting the firmware upgrade. Is there an application for a mac people are aware of that will enable me to browse and play flac files from my readynas duo on the Uniti. I can find a number of local players but nothing that controls the upnp server like plugplayer does on my iPhone
Many thanks
Paul
Posted on: 15 May 2011 by garyi
Songbook or Kinksy. The later requires the install of X11 and Mono. The former does not.
Posted on: 15 May 2011 by jfritzen
You probably didn't expect this, but in fact there is also a PlugPlayer for Snow Leopard, available via the Mac OS App Store for some cents. It seems not to be as stable yet as the iPhone PlugPlayer, but should be worth a try for you. Be sure to stop other UPnP applications on your Mac or PlugPlayer won't start.
KR
Jochen
